peteg59
Meme Master
Is there a "dipstick" on the filler cap?
I'm curious, as the angle it enters the tank looks steep:Shrug:
This last week was BUSY!
We did get to spend a bit of time on the Sporty chop.
Here are a few pics of the 1st Gen Jockey shift we made with the 3D printer.
Shift arm added-
We did not like how the pivot arm was so far forward up top. So we made a different pivot arm that is more upright on top.
Another view-
After much looking & playing with it, we decided we did not like it at all.
We made the following decisions:
1. The S-shaped shifter arm is cool (to us), but it sticks out too far. It is being redesigned with 1 less curve in it.
2. The main bracket (XXXX) is too big and ugly. A smaller one is being designed and will mount up at A & B points shown in the photo below.
3. The whole concept of a pivot arm (Y) & accompanying shift lever plate was interesting, and different, but in the end it was too busy, & has leverage challenges. So we are starting fresh, and we'll have a simpler design printed out soon.
After putting that to bed, we spent a couple of hours looking for fresh ideas on a foot clutch. We came up with a few different drawings (can't find the photo's I took of them), but we still have not settled on one.
We even spent about 45 minutes studying how the cams on a compound bow works, seeing if we want to use something similar in the foot clutch design.
We did come up with one steampunk style design that is pretty cool, but I don't want to use it on this particular bike where I am trying to keep everything as clean/simple looking as possible.
Any ideas, photo's or drawings are appreciated.
What about combining the Shifter Arm and Pivot Arm (Y) into one piece. That would make it less busy and may take care of some of the leverage challenges.
They look fairly rugged as is, so making the main bracketry smaller might compromise overall durability?
Perhaps you could make the final renditions out of stainless plate, with some type of ball milling or other decorative machining to make them more eye appealing without attracting too much attention away from the rest of the build?
Keep up the good work!:clapping:
My engineering degree is still yet to be had, but rallsqh's suggestion sounds reasonable. Less is sometimes better.
It might take a try or 2 to get the shifter into its "ergonomically optimal" position, so the 3D printing perhaps comes into play from a financial standpoint as well...:Shrug:
If it feels "right" when seated, its probably good. I would agree that Hurst makes a cool looking knob.:clapping:
Tucking it inboard might also disrupt the comfort factor you're looking to achieve?
It does look like a potential problem IF you were riding it through the woods, as branches might inadvertently pop it into a higher gear.
Other than that, I'd leave as~is. It sucks redoing something after its "done" but this is a relatively minor tweak, if any is really needed later...
Your progress on this bike looks great Kevin:clapping:
Pardon my ignorance please, but what is the advantage of using an EFI coil over say an aftermarket dual fire type?
That kit looks like it would conceal easily while also providing a clean look.
Never used one but if it comes with an extra FOB as is pictured?, & is fairly water resistant, it might be a good way to go.
Another consideration might be how easy it is to get a "spare" FOB if traveling & your main FOB gets lost?
Guess you could always "hotwire" it in an emergency though, so it might make the replacement FOB factor moot...:Shrug:
