progressive 416 air shocks
has anyone puy these shocks on there trike , converted or tri glide
i have a 2016 road glide special and can't use the standard shocks as they ate spring with adjust meant on just one side like the new 2017 models in us I'm told
problem is that coil overs may be too wide at the bottom and rub against the excel cover. here is my dilemma!
the ones progressive have as change from standard on the road glide also has a spring rating as 80-120 lbs per inch and the one that replaces the tri glide is 125-180 lbs per inch
my road glide would be closer to the freedom id think , but they recommend the 444 with is a coil over and not sure it'd fit
any help here would be appreciated as i don't want to spend 800 dollars and find its no good
pat help?
416 air
several here have put 444's on their TRI-GLIDES without issue.
sorry mate the kit i have is frankenstein and with the later model frames coil overs won't fit . the smaller diameter shaft of the air shocks should fit so its only the 416 series that I'm considering, but no one seems to have used them
also I'm new to this and didn't mean to put this post in the freedom group
thanks Pat
