2013 Stallion electrical problems
Our stallion has check engine light on and door open light on. The fuel gauge works but none of the other gauges work.
My husband can't find any bad fuses. Has anyone ever had this problem?
There is a diagnostic plug under the hood around the oil filler. If a diagnostic tester is connected it should give you a trouble code. It is the same diagnostic
tester used on most late model cars. If you locate the plug, Autozone and some other automotive parts retailers will connected their tester and check it for you.
You can purchase a small tester for around $75. Good to have around. I have not seen that particular problem on this forum in over six years. Hope that you can locate the problem.
having the same problem
I seem to have isolated it to the wiring harnesses and plugs on the left side between the power distribution bos and the instrument panel. also thought possibly a loose ground connection on the competer.... still troubleshooting though
