Anyone installed these pipes. I am putting them on mine and there is not a lot of clearance on the right side between the adapter and the frame. Anyone else experience this?
Thanks for the reply... if you don't mind, how much room do you have on the right side between the frame and the muffler adapter? Mine is tight against the frame. That does not see right to me.
Thanks for checking .. mine is 2015 too. The top pipe seems to be up too far on mine and interferes with the frame. I would literally have to pry down on the pipe to get the muffler adapter on. When I release the tension, the pipe comes back up and the adapter rubs on the frame. Not sure what the hell is going on with it. The pipes are in the heads..the bottom pipe fits fine.
Do you have a lift on yours? Though I can't see how it would matter. In my mind that should improve clearance.
Thanks guys... I am waiting for Rush to send me replacement pipes under warranty.. Stay tuned.
