Jacking up a Tri-Glide
Mar 29, 2016
42
29
Tehachapi, CA
Robert
How do you jack up a Tri Glide? The service manual says to place a jack under the frame centered under the clutch cover but the trike's center of gravity is aft of that point such that the trike tilts back when you raise it and the front wheel comes up instead. The service manual says as an alternative you can jack one side or the other using a jack under the axle but I want to raise the whole back end. I'm working on the garage floor so I have no way of strapping the front wheel down. How do the rest of you do it? Thanks.
A cheapo motorcycle jack ( I have 2 ) won't balance a tri-glide or a freewheeler. I jack the rear, use axel stands to hold it up, then use the jack and lift the front. I've read here that some of the more expensive jacks will lift and balance the whole trike, I'm just not comfortable. I've always had great luck with Antelope Valley Harley, they aren't too far from you
I don't have a TG but I put a scissor jack under the motor frame. Then bring the rear with a hydraulic under the rear body where the tow bar would be. When high enough I put two car jack stands under the axles solid and works great. My wish list is for a table lift on a birthday or Xmas maybe. Maybe my wife will read this..:clapping:
I have 2 scissor jacks, one 4 inch wide and the other 6 inch wide. Works pretty good, but a chore to get all 3 wheels off the floor. Yesterday I drove the trike on floor ramps. It was not hard, just needed a lot of throttle and the Sweetie to make sure I didn't ride over the edge. I thought I would try this since I am changing out the header to a non catt, adding floorboard extensions, relocating the oil filter and adding an oil cooler. Laying on the floor is hard on the old body. Jim
Thanks for the ideas. A couple of you have suggested (if I understand correctly) to jack the trike at the rear frame under the body. I question whether that is strong enough as it is just a bolt-on frame assembly for supporting the body and mufflers and not listed as a jacking point in the service manual. The J&S Jack looks neat except that in addition to the frame under the engine it also uses the front of the rear fork (swing arm) as a jack point which is not listed as a jacking point in the service manual either. How much stress does it put on the fork pivot bearings/bushings and the rear transmission mount casting?
Same here. I'm awaiting the money to buy the relocation kit and oil cooler for mine. I will most likely lay on the ground though. It will be incentive to both get it done right the first time, and get done fast.
I use a J&S jack. Lifts the entire trike off the ground up to 18 inches high. You can roll the jack around in your garage with the trike on it. I store mine up in the air during the winter.
http://www.jsjacks.com/trike-lift/trike-lift/
This is awesome. Wish I had the money for it. And yes, I know for what it is, it's way cheap.
I also use automotive ramps. But I put a rug down on the floor & under the whole ramp also that the rear wheel is on before it tries to run up the ramp. This holds the ramp stationary for you. Sit the ramp towards the outside of the rear tire so you are sure to clear the floor boards.
Then if I need the front end up also I use the floor jack (motorcycle jack) to lift the front wheel & put a third ramp up front. While on the ramps I sit on a mechanics stool & just scoot around the trike to do things on the outside.
When it is time to dis-mount, just slowly reverse the trike to the ramp portion & hold the front & rear brakes to go down easy to the floor. Works great for not having a lift table. Plenty of room under the trike to do whatever you need to do also. But get the tallest ramps you can find. I have the metal ramps.
I use a J&S trike jack .... but adapters can be found for regular cycle jacks. Here is a picture of a Pitbull adapter showing where it goes. The J&S trike jack has this feature built in. A J&S trike jack can also be fitted with an adapter rail making it work with regular.
I drilled 2 holes maybe 18" apart in my shop floor and put in those Red Top taps. I got 2 eye bolts that I screw into those taps and run the trike front wheel in between them. Tie the front down and jack up the trike to slide auto ramps under the rear wheels. I can then if necessary release the front end and jack it up and rest the front of the frame on jack stands.
When I finished I jack it up, remove the front jack stands, and back the trike off the ramps. I tried driving upon the ramps one time, using a rug as suggested. One ramp caught and the other didn't.....scared the holy crap out of me.
Ohhh, when I'm finished I push a plastic automotive carpet tab into each of the taps. Keeps the dirt out of the theads.
8~\o
One thing I have noticed using the J&S trike jack on many TriGlides is that the crossover exhaust clamp nut often has to be rotated out of the way if it hits the forward rail of the jack.
I have been using the Pro-Series Equipment Lift Table. A bit more than the J&S, but I like the full table much better.
If I need the back wheels off the table I use the scissor jack that came with the Lift Table, at the factory lift point, and with the front wheel in the clamp, and strapped down, it works fine.
Before the table I would use a hydraulic jack to get one side lifted, then put a jack stand under the cross member on that side and then left the other side and do the same. I would butt the front wheel up against a wall, or lock the front brake, to prevent any movement.
Here is a link to the thread on the Lift Table-
http://www.triketalk.com/forum/threads/25171-Testing-out-the-new-lift
jack up trike
8~\o
I didn't think you could get that far down us old guys aren't so flexible
When I put my lift kit on I ran a long bar through the front axle and used some tie down straps around some sand bags to hold the front end down. Used a floor jack at the rear frame and raised it up. Necessity is a mother, to coin a phrase.
Ahhhh the getting down ain't the problem at '71, it's the getting up that an issue. Ha!!!!
8~\o
Don't know about the getting up part but my problem is if I get down on the ground like that I think to myself while I'm here in this position may as well take a nap. I don't understand how little kids fight taking a nap at my age I would be willing to pay for a nap.
Any one of you J & S jack owners have a trike with Vance & Hines Power Duals? Any problems with clearance issues?
You can still find these out there Pitbull Trike Jack
This one is air assist.
Old post but still worth 2 cents mentioning it because Non of the companies mentioned in this thread build trike lifts any longer.Pit Bull Trike Jack.jpgpitbull trike adapter installed.jpgPit Bull Lift Pic.jpg
Since this older thread was revived earlier today by a couple members…. I will share a video and an idea that may hopefully help others on here since the Post title is about “lifting a Tri Glide”.
Coincidentally this past week, I was just getting done with some custom made steel “adapter blocks” for my trolly jack and tonight I finished them and decided to also make a short video.
I also have a couple scissor jacks that I use often (mainly for lifting the front… sometimes I’ve used them in the rear too), but I mainly use my bottle jack and a trolly jack for the rear. So the custom made adapter blocks were made specifically just for the rear.
A good friend just last week was using blocks of wood and his split on him, almost having an accident. So I decided to make these custom made “adapter blocks” that I will now use for my set up.
(Yes, I’m making another set for my bud, too!)
Hopefully the video will help others with some ideas, but always keep safety a #1 rule!
Video link:
Great idea and tip,thanks for sharing, much safer in my view, what hole size did you drill?
I am actually going to weld a 1/4” thick “ring” that the trolly jack head will fit inside.
This way there is 100% captured safety and the lift adapter will not slip off at all.
(FYI: KustomFX, LLC may decide to start making these for sale and most likely will be up on the website first of the year).
Pics of the “ring” that will be welded to the bottom of the lifting adapter:
Joe Henry
