gear rpm
Feb 16, 2016
23
1
Loganville, GA
Paul
when I select this mode on my freewheeler the rpm's are always displayed but the gear you are in is not displayed until you start moving.is this the way everybody 's operates or is it just mine? im just about ready for my 1000 mile warranty check.
Apples to Oranges Here:Shrug:; Thats the way my Victory works... Also when i pull in the clutch at any speed the gear indicator will turn of in-till i release the clutch again...
My 11 Tri only has a 6Th gear indicator and it will turn off when the clutch is pull in...
Gear indicator does not read actual gear bike is in - it's a number generated by the computer comparing RPM and MPH. Disabled when bike is stopped or clutch pulled. All FWs do it, so yours is normal. You can mess it up (and your cruise control) by making too big of a tire size change.
This is correct.
