Harley trike oil coolers
We have been installing Ultra Cool and Love Jugs for years with great results (especially the newer dual fan Ultra Cools). In our experience the need for these add-ons is mostly either with performance-enhanced motors and/or motorcycles that are ridden in really hot climates at slow speeds. That's when these items really "show their stuff."
Everyone is talking about Maximum oil temps, What is the Minimum temps??
Sometimes Too low is just as harmful as too high....:Shrug:
Oil temps 195 and above Will ensure the moisture is evaporated
Yes, 195 should be close to the minimum, and 220-230 is a really comfortable temp for the human and the engine.
However, most Tri-Glides, including the waterheads, are running temps between 290 and 330 from the factory. That is too hot!
I would bet dollars to donuts that an engine running at 300+ will have problems sooner than one running at 180...and the one running at 300 will also not run nearly as strong.
Bottom line, a person can do a ton of stuff to cool down their oil temps on a TG and they are not going to have a problem of it running the oil temps below 195. :)
I am currently running a Harley oil on a 2008 103 cu in ultra classic triked by MotorTrike . I was running down the interstate doing about 75 mph in 6th gear and looked at my oil temp gauge reading 286. I realize that pushing a 1125 lbs + me takes a lot , but on a 90 degree day that seemed a bit high.
I have been looking at the oil coolers that are out there, oil bud , ultra cool, jagg, etc.. Anyone have any suggestions or advice? I am running the Axtell oil pressure relief kit also.
Leaning toward the Ultra Cool because of the fan assist and 19 rows of cooling, but I am willing to listen to any advise.
Thanks , Riderdave:cool:
Jagg:
is a good product,1) Harley routes dirty oil threw the cooler first before the oil filter, I like jaggs way better ,they go threw the oil filter first then the cooler.
Also a 40 degree drop with fan assist.
Buds:
is a quit impressive oil cooler that goes under the bike
35 degrees drop without any fan,so stop and go traffic will not
Effect cooling. And it will take a shotgun blast ! So any rock kicked up from the streets doesn't have a chance to penetrate the cooler . Just saying tough stuff ! See videos
Baker:
makes a 1.5 extra qt oil pan that's impressive . Two chambers upper and lower ,as the oil cools .
To start with, my cooling journey started with stage one .
Decat head pipe,air cleaner and a good fuelmoto tune. Added the biggest s-69 (big schlong) stainless steel medical grade filter . That flows 7 times more oil than any paper filter. Clean and reuse,also built in fins adds cooling . All that makes things nicer. I'm leaning on buds as my next upgrade. Hope this helps
Ron A
