Anyone knows the rim size, bolt pattern and offset ? I do know mine are 5 lug rim. The rims will need replacing when I change out the tires. Got some rust on them and don't like that.
thanks, David
thanks, David
thanks, David
If you pull the wheels off, the information you're looking for is stamped into the rim on the back side. That's the only way to insure you're getting the same rim and it will work correctly.
I know my stock wheels are 15" and I think they are a Ford bolt pattern.
Call MT and they will tell you.
Also if your rust is not real bad, try some NAVAL JELLY to remove rust and wax real good with a good chrome polish.
Thanks. Haven't been able to see the marking on the rims.spyder 2+2 solid ax
Here are the MT rear wheel specs
Wheel size:
15 (381mm) x 7 (178mm)
Backspace:
4 1/2 (115mm)
Offset:
0.5 (13mm)
LUGS:
5 lug on 4 1/2 / (5x114mm)
