Rear rim size Motor trike coupe
Sep 3, 2012
89
85
Magnolia, MS
Warlock
Anyone knows the rim size, bolt pattern and offset ? I do know mine are 5 lug rim. The rims will need replacing when I change out the tires. Got some rust on them and don't like that.
thanks, David
thanks, David
I know my stock wheels are 15" and I think they are a Ford bolt pattern.
Call MT and they will tell you.
Also if your rust is not real bad, try some NAVAL JELLY to remove rust and wax real good with a good chrome polish.
If you pull the wheels off, the information you're looking for is stamped into the rim on the back side. That's the only way to insure you're getting the same rim and it will work correctly.
Thanks for the info.
David
Starting to bubble. Too far gone to recover. Naval Jelly is some good stuff.
thanks, David
Reyphi
