2015 Tri Glide Spot Lights
I have a 2015 Tri Glide and the spot lights won't stay on. If I hold the button down they come on and stay on. Once I let up on the button they go off. The high beam on the headlight is off so it isn't that. Any ideas? Please help. Thanks.
the newer touring models have what is called a body computer module. Yes much like the ecm that we all know about. This BCM controls all the switches and lights etc. You should still be under warrantee it sounds like they need to re-program the BCM.
I had a similar problem. The fix was easy once I saw what was going on. I usually leave the spot light switch on, but bumped it while cleaning the bike one day. It then did exactly what you are saying. What I noticed after working at it for a few minutes is that it never popped completely up; grabbing it with my fingers I was able to pull up on it to get it completely up. It then worked normally again.
Give it a try!
LOL - Me too...one day the switch is fine, then not. Dealer put the new switch in intimating that it was not the first one they had to replace. Also had them change the HI beam / highway light debacle. Took them about 30 sec. to change the program.
Milia
