Cargo Rack
Sep 16, 2009
805
77
Myrtle Beach, SC
Tom
As it goes I can never leave well enough alone. I have had another carry rack built that hopefully will serve what I want it for many years to come. I added the ability to disconnect the rack without laying on the ground.
Now that will hold a lot of stuff!
Looks good. I noticed it had wiring, is there lights or just wired for lights
There is a light bar on the rear. Has running, brake and turn signals. If I find some small id lights for the side I might add them later. For now Im going to add some high reflective red tape strips to it
I bought another ball mount like this one http://www.carid.com/curt/class-1-ba...UV0aApdV8P8HAQ
and bought a raw 1 1/4" receiver tube http://www.ebay.com/itm/Curt-49506-R...aa337a&vxp=mtr
I needed the 11 9/16" length ball mount for the total length to get past my rear bumper.
I cut the ball mount about halfway through the bend removing the rest of the mount that I didnt need.
I made a 45 degree cut removing about 3" of the receiver tube that I didnt need. Using my neighbor mig welder I tacked the ball mount and receiver tube at the angle I wanted.
My buddy who welds, does metal fabrication for go carts and does the powder coating made the tube tray to my specs, finished welding everything as needed and powder coated it for me. This wider cargo carrier is for my modified knee scooter that I carry when Im going to museums or have a need for the use of it. It also can carry other things as well.
Being a A/K disabled rider its tough even in my garage to get on the floor to put the hitch pin in. Having the ability to remove the rack if Im at a location for a few days was something I had on my mind for several years with my smaller rack I was using.
I have a H/F trailer with a cargo box in the garage. I know there will be a time and place to use it. But for now, this rack I had help making will do for me as needed.
I am looking for a cargo bag now to put my scooter in and will have another pic once I get the bag.
Dimensions
FLTR2008TRIKt
What are the inside dimensions of the cargo box? It may be a better way to carry my wheelchair. It's a manual type that weighs about 20#. What I use now is the type of carrier that mounts on the back of cages. It does not hold up well.
FLTR2008TRIKt
36"x22" the carrier you are using needs a upper support to stabilize it. I have a George Anderson tour pack relocation plate that is made of plate steel. I have considered making a carrier for my wheelchair. The downside is access to the trunk.
I'm fortunate for now I can stand and walk for short periods before I have sit back down. I modified a knee scooter that I carry with me that I use as a aid when I visit museums.
http://s993.photobucket.com/user/fltr2008trike/media/0905152105_zpstntpii24.jpg.html?sort=3&o=2
I have a small Harbor Freight trailer with a cargo box attached to it for those times I have to have my wheelchair
cargo box and wheelchair
You're right about trunk access being a pain. But, if I pull the chair off and the vertical bar for the top mount, I get full access. I'll be measuring my ti-lite titanium super light chair to see if it would fit. (Thanks to the VA) I also just moved my TourPac box back 1" which leave me some pretty hefty stock to mount an upper brace to.
Ride Safe,
Scott Smith
MRB
