The noise developed over time and it is getting worse.Has the noise developed over time, or after the trike was washed ? Is the belt tracking properly or in need of adjustment ? Might be an un-related to belt noise vibration ?
I have a 2010 Kawasaki Voyager that I triked with a Champion kit and a noise on acceleration has developed. There is some play in the axles when I move the belt pulley by hand. any help or ideas will be appreciated.
dan
P.s. Im not clear on whether of not its belt drive but it sounded that way?
You would be surprised at what a rock in the belt will sound like?
Very noticeable at certain times like acceleration and not so noticeable other times?:Shrug:
Graybeard
Are you saying that you can move the axle and drive pulley for and aft .050 (fifty thousands) or 1/2 inch. .050 is kind of hard to see with the naked eye. I sounds like maybe some of the attachment bolts are loose and the adjusting bolt or the left side is loose. I will check mine tomorrow after my dr. visit.
The belt is tracking properly.
can you reach under the seat area and pull the large pulley back and forth inline with the belt and tell me if you can move the pulley and axles at all I can move mine about .05 inches back and forth.
thanks
Dan
