instrument bulbs
Mar 22, 2013
394
51
Thonotoassa, FL
Doc
has anyone changed to LED bulbs and or changed the color of the bulbs ,I have a white faced dash replacement to change out in the near future and want to change to red bulbs and brighter turns bulbs.. * * * Also what is / was the bulb replacement number
1pair T5 Wedge 5050 Red SMD Gauge Cluster Speedometer LED Light Bulb 57 79 18 74
(2) T5 Wedge 5050 SMD Blue Speedometer Gauge Cluster LED Light Bulb 57 37 73 257
10X 74 2721 Twist-in Green Instrument Panel Dash Light LED Bulb PC74 Sockets T5
These are the bulbs from e-bay that I purchased to do the same thing. Turned out great.
thanks i'll try to check them out
Hello
after adding the new lights to the instrument cluster,
did you use the colored lights red, or green, ect. did it make it any easier
to see the speedometer. I am going to change the gage faces and then change
out the bulbs. I ordered 10 red and 10 white t5 replacement leds. I am planning on putting
a bright white led in the speedo hole and the blinker holes all the rest red.
Thanx
Dragon
THANKS FOR THE INFO looks like i'll be changing the dash out sooner than i thought as mine now is soaked with coolant
Good Morning
I finally got my custom face gage kit from carid.
Well got the package open and it looked like someone threw in
a handful of needles and the faceplates were just floating around in the box.
there were 8 needles in the box and none of them fit. called tech support
and was told they would solve the problem within 24-48 hours, ok.
after a week I call them back and tell them to refund my money.
put the old cluster back together with new led lights anyway.
sure would liked to have the new look as long as I had it apart :mad:.
I used 9 red led bulbs and 1 super white led for speedometer.
Dragon
Good Morning
Dragon
thanks for inf what were the bulbs that you used ?
Hi Doc
As was posted by gorilla they were t5 wedge. bought the lights on amazon
came in 10 led light packs .One set came with new wedges and the other didn't.
did have to play with the mounting as one way they work and the other they
won't come on. put the lights in go plug in cluster see what works and then
pull cluster back out reverse lights put cluster back in and make sure all lights work.
the only problem is I don't know if my cruise light works as it doesn't come on
when sitting. I think the vehicle has to be moving for it to come on and set?
Dragon
Hi Doc
Dragon
thanks for the respond ,still under the weather so to speak and havn't done the change out as of yet
Good morning
This is what I have found after installing the led lights. the led's are brighter but they act more
like a spot light, meaning the led just has a bulb on the top of the plugin and pattern is just as a spot,
the bulb on the other hand lights in all directions and gives a spread out pattern. the instrument panel
inside where the lights go are made to have certain areas light up in a group and a spread out pattern.
so I guess what I am saying is the led's just quite don't light a large area. a dimmer switch would light
up the area better.
Dragon
I guess those would work way better, oh well maybe next year if I take it apart again.
they are cheap lights. now it is all locked up and sealed and ready for the road.
Dragon
Cline
