replacing handle bars
leonard
70+ Posts
Oct 30, 2014
80
41
Kearney, MO
Leonard
when adding longer front brake hose on 2014 tri glide do you have to bleed all the brakes or just the front. I know you have to bleed by circuit but not sure if I have to bleed the back brakes also.
I would look more on that. I do not have linked so I can't look to be sure, but if you are not disturbing the hoses for the link or the rear bleeding the front should work.
2014/15 - The rears are linked to one piston on each side in the front. The front brake lever runs the other 2 pistons on each side. That is why there are 2 lines coming in to each caliper. There are 2 bleeders on each caliper. You only have to bleed the front system.
Bob :Dorag:
MelvinGira
