Thought I would try this, if it doesn't hold up I can peel it off and try truck bed liner, etc. It has been on two days and about 400 miles. I have cleaned them with plain water, so far so good.
How did you apply it? Spray? Roller? Brush?
From a spray can.
Bought some today at ACE hardware. I'll do the fenders this week.
Now that's something I hadn't thought of. Need to do something as I keep getting black scuffs on my left fender. From what I hear about it is it's easily removable if it doesn't work out.
I did my rear wheels
None, its so thin that the balance offset is negligibleAny issues with wheel balance? I like the idea and look.
How did you get the tape line to stay down?? I did mine yesterday and could not get the tape to seperate from the Plasti Dip. Other than that I think it is a great product. Went on fine and pealed of just as fine. I used the clear and it was a matt finish. looked good.
thought i would try this, if it doesn't hold up i can peel it off and try truck bed liner, etc. It has been on two days and about 400 miles. I have cleaned them with plain water, so far so good.
how many cans did you use to get your affect?
Manufacturer suggest 12 mil thick and says each coat is 2-5 mil.
Did you use the plasti dip glossifier after finishing?
Where does one usually find plasti dip retail? Autozone or something?
Thanks.
Thanks.
Thanks.
I used a can and a half. Got mine at Home Depot. Did not use the glossifier.
Thank you:
Was there a reason you didn't use it or was it preference?
