Special Performance Air for Tires and Shocks
Oct 20, 2014
707
190
Lancaster, SC
Steve
Ok...just between us... Don't tell the two wheel crowd. I got the hybrid hydrogen hi performance air for my tires and shocks today. It's 78% N , 21% O2 and .93 % Argon with some trace H20. The price is really cheap, usually 50 cents at the local station for the tires and free using my little shock air pump for the tires. Available almost everywhere except Los Angeles and New York City. They even have it in Canada and Alaska ! Of Course, you should check your tires and shocks prior to riding for best results.
It's another rainy day
So how does it ride now that you have put this special formula into your suspension? Does it have a special name?
Its not raining here but work does drag on sometimes.
Well after a mere-100 mile ride, my teeth are whiter, breath fresher and I have less gas. It is great and it is guaranteed not to rip rust, tear bust, fray at the knees tear at the cuffs and collars, good for colds, moles sore buttholes and bumps on the belly.
If you use it in large volumes it will void your tire warranty ...
So be careful..:xszpv:
Why not Helium :Shrug:
Wouldn't Helium make the Tires (and therefore the Bike/Trike) rise and lift resulting in less friction which would increase MPG and Tire longevity?
Makes sense don't it ;)
Then again, would you then need a Pilot's License?
Can you imagine how expensive chrome HD or Kuryakyn Ailerons or Canards for steering would be?
Wonder what degree Rake those would need to be?
Would you mount then forward or reverse?
Hmmm,,, time to PM Bazooka. He'll know :D
Thanks for the advise, cured my hemorrhoids.
