Boom Trike
Dec 1, 2014
3
1
Cloverdale, Ca
I have a 2004 Boom Trike Lowrider. It came with a Berga (European) battery. It's time replace the battery, but I have found that the correct Berga is not available in the U.S.
The European batteries have recessed lugs that are flush with the top of the battery, not like American batteries with the lugs sticking up above the top of the battery.
Has anyone replaced their battery in a Boom Lowrider? I think an American size group 26 might fit, but there is a clearance problem between the battery lugs and the body bracketry.
I got no help from the Boom Dealer in Florida when I asked them.
There are lots of battery's on the market with side attachments though I really don't know the configuration you speak of?
However I am really interested in seeing some photos of your trike, I don't think I have ever seen a boom lowrider?
I have no answer for you, but here is a link of other Boom dealers. Perhaps one of them can help you out.
http://www.boomtrikesusa.com/dealers.html
Hope that helps. I do not know anything about any of them.
I have already seen this link . I can't seem to email these as I get some kind of Outlook error. So, I guess I'll give them a call.
Thanks.
I am trying to do this without changing cables or clamps. But yes, this is an alternate solution.
If you go to the following link and scroll down to the picture of the dealership, my lowrider looks just like the red one in the front of the pic. Except mine has purple flames on the tank and fenders.
I will post a couple of pics of the trike soon.
Thanks.
nice looking unit! thanks
Well, it has been awhile but I had found a solution to the replacement battery problem. I thought I had better let you know.
Actually it was quite simple. I found that a Group 26 battery was close to the correct physical size, tho' a bit taller than the original European battery, which was my original concern. The battery posts would hit the trike body. But my local O'reilly's had a Group 26R with reversed polarity. So, I turned the battery around so the posts were towards the back of the trike. That way the cable polarity matched up with the polarity of the posts, with plenty of headroom. The battery fit the tray, and the battery hold-down fit the lip perfectly.
So, there you go.
Sfeddie
JeroldBurr
