rake kit
Is there a way to tell if my trike has a raked front end? Is there a measurement you ca do?
Mike
If you can recognize the upper Triple Tree Clamp that the handlebars attach too, Honda usually paints them black. The aftermarket TREE is usually unpainted aluminum.
Find a stock two wheeler and measure between a point on the cowl and the rear of the front fender. Then measure your trike at same spot. If distance is greater than stock bike then you have a rake kit.
Reyphi
