18" wheels with low profile tires
Jul 2, 2011
28
youngstown, ohio
I have a 2011 harley trike and am thinking about running 18" wheels . I'm wondering about if they change the ride because they run with low profile tires(215/45/18). The wheels look great as apposed to the stock wheels which I really don't like. The trike rides rough and I'm wondering if the tires will make it even worse.The larger wheel also will let you run larger rotors which will greatly improve braking as apposed to the terrible stock ones. Is there anyone running 18" wheels? some feedback would really be appreciated.
My experience is with car tires, but anytime I've gone with a low profile sidewall, the ride of the vehicle has suffered. But it looks badass! :D
Hopefully you'll find some info. I've been trying to search around for wheels other than stock, but no-one seems to know what I can use. The only ones anyone's mentioned are the hd anarchy. Guessing the trike wheel dimensions are tough to match.
low profile look great but you loose all tire sidewall flex so I hope you ride on really flat roads or you have very smooth suspension as you will feel every bump and dip in the road.... If you travel rough roads on cars the rims crack over time and often need repairing...although that will be less of an issue with the trikes lighter weight
Re: 18" wheels with low profile tires
check Performancemachine.com. they have some wheels there.
The wheel diameter is larger and the tire diameter is smaller. I've been told by the manufacture one cancels out the other which doesn't change the speedo.
Click HERE for a very handy "wheel vs tire size" calculator. Enter your current wheel & tire size in the left column, then enter your "proposed" wheel & tire size in the next column(s). All the results (overall diameter, revolutions per mile, speedometer error, etc.) are self explanatory.
Good luck with your project.
I have heard that the older Mazda Miata wheels will fit. But I have never pursued that rumor. I can't remember the measurements for the wheel right now, but you could measure everything & have a tire/wheel dealer find all his options for ya.
Whan you measure the offset, & everything but width is measured off the back inside machined surface of the wheel.
I have the larger H-D Anachary wheels and the ride is definately harsher, less sidewall give, but they sure look great and are the easiest wheels to clean, which is the reason I bought them. Of course they come off every November when I put on my winter wheels/tires. ThumbUp
The only thing that touches my Anarchy wheels is Windex. No abrasive chrome cleaners, and they're all abrasive to some extent. Just look at a chrome piece after a year using a chrome cleaner - very microscopic scratches.
I use a foaming chrome wheel cleaner from Griots Garage along with their boars hair brush on chrome wheels.
Problem with performance is I'm looking at black wheels, they have chrome. Most places I go to are having a problem with the offset and backspacing. They have nothing in their systems to compare to the stock wheel. Does anyone have sizes that I can go in with for a comparison, a lot of places aren't sure of the clearance issues with the caliper and fenders. If anyone who got wheels already can give me the backsliding and offset they bought maybe they can work off that.
Thanks.
ck out 131042152639 on ebay
I've been checking eBay and that's what I'm trying to get a answer on. Those wheels will they fit? I thought we had 4 X 108, those show 4x100, and then there's the Offset and backspace, ebay has a lot of wheels by I'm not sure what I need to get for offset and backspace in order to fit.
If you would like riding on a buckboard with wooden wheels, go ahead.lol
Bullet Proof
