Hearing a ticking noise
Aug 4, 2012
42
7
meridian, id
About two weeks ago I started hearing a ticking noise on my 2011 TG which has about 9k miles. It kinda sounds like rocker noise or an out of adjustment lifter on a car engine. I begin to noticing the noise above 2000 rpm on a fully warmed engine. Last week I stopped by my local HD Service and asked if someone could take it for a run. The service guy on the desk ran it around the block and came back and stated he did not hear anything unusual. While riding this weekend, I began to hear the ticking noise again.
When it comes to motorcycles I have no mechanical abilities so I have HD do all my service. However, I did take out the owners manual and checked the oil level and found that it was at the add oil level on the stick. I added about 1/2 quart of HD synthetic to bring the level up to the middle of stick. Took the bike out for a ride and it seemed to help a little but I could still hear the ticking noise.
Is this normal sound?
Or is it the beginning of a major mechanical problem in my engine? Should I be using a different type of oil other than Syn in all 3 holes when they do my 10k service?
Any suggestions or recommendations would greatly be appreciated.
OK try not to laugh but your best bet in finding the noise is a Stethoscope. Play Doctor by placing the scope in the area of the lifters and also up top on the heads to check the rockers. Don't be surprised if you find the area but it will probably turn out to be fairly normal for the HD. If you can isolate the component it will be easier to talk with the dealership. They need all the guidance you can provide. Make sure you have the issue documented by the dealership. You may need this later. Tapping is a common complaint on most harley web sites. I have not heard of any actual serious issue nor have I experienced any long term issue on my bikes. They both have some tapping noise.
09 Softail & 13 TG .
What he said.
Top end noise is normal.
Some have more than others. Most will be louder as it get closer to time to change the oil, and most will be louder in higher ambient temps. Also, different oils will make it louder or quieter.
Maybe chain slap in primary??? if its the left side..??
Maybe have someone else listen maybe someone with good hearing
Some ticking is normal, That said just in case check the front stabilizer bolts.
At the top of the front head they are 9/16 in. there's two bolts. Had mine loosen and they sounded like a lifter..:Shrug:
The only suggestion I have is to get the Syn 3 out of the Primary and put Formula + in it. It will make a difference for a lot of things, but it may not get rid of your ticking sound.
Not to be disagreeable with those who have ticking noises, BUT.....
I certainly would not accept as "normal", any noise that suddenly started coming from the engine that had not been present during the first 9,000 miles.
Just sayin'..... :Shrug:
If it does it at idle i'd be checking the lifters real soon or you may be replacing cams and oil pump. I've just replaced mine for the second time. I only have 17,000 on mine. This time I put in Competition Cam lifters,not stock. The dealership put stock lifters in a high performance motor. That's just plain stupid. This time it was out of warranty. Plus they put a SE oil pump in. I didn't let Harley work on it this time either. If that Tapping gets louder you better get it in quick. Jim
Went for a ride today, and at a stop light i hear that sound again,
Guess i joned myself by mentioning those bolts, They were hand lose ready to fall out...
But experience taught me to carry a 9/16 box wrench with me, So i pulled over tighten them.
When i got home i pulled them out cleaned them with brake cleaner,Then used lock-tight... [again] This will be the third time they came lose in 20 thousand miles...
I had mine come completely out last year when Dennis and I drove to Maggie Valley for the Rally. It was pretty loud. Dennis noticed something different one time when we were stopped in traffic on I-75. It dented my rocker cover. Jim P.S. I'm glad that's all it was.
Don't know which loc-tite you use, but you might try the green bearing mount. It is permanent & would need heat to take apart. But then again, that is what is on those bolts anyway.
If you are under any warranty I would make MOCO put the fix to it!
Out of warranty, But even if it were it isn't worth my time to bring it in, It only takes ten minutes to tighten them up, I've tried the blue first now I'm using red.
And if they loosen again I'll try the green.
There was some left over of factory yellow lock-tite on the treads.:Shrug:
tic started in mine about 8000miles. had it to the dealer 3 times no answers. at 17000 miles now and had to replace 255 cams , lifters , and oil pump. front cam,lifters and oil pump really tore up. my mechanic thinks the front lifter was not installed correctly. waiting to get it back. got s&s 551 cams and s&s lifters. I don't remember what brand of pump but it is a good one and it aint Harley.
I had that ticking noise along with just a sissy feeling from the trike. While in for an oil change the dealer found a new program modification that they added and took away all of that noise and made a much stronger trike out of it. I love it now, but was wondering if I had made a bad purchase before.
There are only 3 pumps available, Feuling, Thayer and Harley. The Thayer is a 3 stage pump which isn't recommended for crankshafts which have not been trued and plugged. I'll your pump may be a Feuling, the S&S lifters are a pretty good lifter so you should be good to go there. Its pretty tough to not install a lifter correctly on the Twin Cam, they have a bar that keeps them from rotating, the bar sets in the right case half and into a flat spot on the lifter, both sides of the lifter have the flat spot and it makes no difference which way the lifter is put in. I'll bet the roller failed which your mechanic should have been able to tell.
Had to take the cage to our southern trip. the night before we left , they were putting my motor back together and knocked the oil pump off the bench . it hit just right and broke. after all this I gave up and went with out the trike. turned out to be a good thing. my buddy and his wife rode 5 hrs in the rain coming home and 2 hrs in the rain getting there. Should be getting it back today. said they had to get a set of adjustable push rods to finish it any way.
hoping for good weather to put a few miles on before its to cold............
S&S 551 cams are a bolt in which can use the stock push rods vs adjustables.
well, the bad got worse!! I got my trike back about 2 weeks ago from the shop. sounded worse than when it went in. shop owner said its just the way v twins are. he advised I just ride it and we will reset the push rods in about 1000 miles. rode 40miles and it quit running. called the shop from where it broke down. got no help from them. just said well, bring it back( like that's going to happen!!) took it to 4 rivers Harley in paducha ky. waiting for it to be fixed again.
I think my next stop will be court with the firt shop.
It sure sounds like the 1st shop is a stinker and your next course of action will be court. Obviously the 1st shop doesn't realize or maybe doesn't care you could have had one of the adjustable pushrods come loose. This has happened to folks, sometimes with no damage and then other times there is damage related to the pushrod loosening up. One of the reasons I don't use adjustable pushrods, even on larger non stock base circle cams.
shop #2 are telling me that 2 of the push rods are loose but the lock nuts are tight. I replaced the 255 s.e. with s&s 551 easy start cam . now I guess a compression test is out of the question so the heads will have to come off and be checked. when shop #1 replaced my oil pump , the cam plate looked good but the bushing was bad. they replaced the bushing on there second attempt (screwed up the first bushing. guess they didn't get it straight) Im hoping they didn't mess up the plate . I have a vision of the bushing stuck to the shaft and spinning inside of the plate and causing the major noise im hearing
im not a bike mechanic but have been around race cars and trained as an auto machinests apprentice as a kid .so my imagination is my worst enemy right now.
I guess time will tell. I told shop #2 I don't want it back till its 100% right.
I would hate to be the guys at shop#2. I have seen basket cases and being the one trying to straighten out another shops mistakes is a heavy load. Hopefully the tech at shop # 2 will be able to solve the mistiry of what started the whole thing, what shop # 1 did and what to do to get it right.
Looks like shop number 1 did you no favors, they didn't even get cam selection correct. With the Triglide having Automatic Compression Release's (ACR) there really is no need for easy start cams. With the easy start cams and ACR's you could run into not having enough compression to fire the engine.
HD has it programmed to not let the spark plugs spark when the compression is low. With a new good working engine this shouldn't be a problem, let the engine gain miles and maybe loose some compression this could happen.
The only fix if this would become a problem is to disable the ACR's using either a tuner or having the dealer do it with the digital tech.
Dealers like #1 should be drug out back and put out of their misery.
I guess the h.d. dealer got it figured out. shop #1 put in a lifter set that has a limited bleed down to help with compression. along with the easy start cam. then used my stock push rod tubes with crane adjustable push rods. this is a bad combination and caused a lot of problems.
shop # 2 got I figured out. put in se lifters and push rods . started right up. funny how that happens when you know your stuff.
Kickstand_Korner
