Tool for 14 tri gllide water check
Sep 2, 2013
203
50
Monroe, OH
Mike
I found a set of plastic pry bars that Harbor Freight carries for $6.00. There is one pry bar that works perfectly to pop off the cover for checking coolant on the right lower and popping off the grates that cover the radiator fins to clean them. Since it is made of nylon it will not scratch any part of the trike and it is easy to keep in the pouch in the tour pak. Harbor freight part number is 69668.
4 Piece Nylon Pry Bar Installer Kit
Say, it occurs to me. Has HD finally broken down and put a temp gauge on the '14's?
Still just an air temp, but not a "gauge".
You have to press the "Information" button on the right hand grip switches. The infotainment system displays the Air Temp, Oil Pressure and the status of the EITMS.
