Squeak in conversion kit
FRR
Oct 12, 2012
1,581
399
Batavia, OH
Fred
I had a CSC conversion kit put on my 2004 Wing last November. I've noticed the last few days that when I ride over bumpy roads my kit will Squeak when I am turning. Sometimes when I get off the bike I will get a squeak out of the rear end after it is parked and I move the bike from side to side. Doesn't happen all the time, but it seems to be getting more noticeable. Anyone had this issue and how did you remedy it? I'm thinking about putting it up on a jack and taking some lubricate and just spraying everywhere I can imagine it coming from..
Any experiences like this and what did you do to fix the problem? Thanks in advance
If you take the seat off, you should be able to see both heim joints at either end of the shock. These are not self lubricated and may be where your squeak is coming from. I sprayed mine with Tri-Flow.
Pulled both wheels off and the seat. Sprayed silicone on everything that moved. Squeak is gone but the A channel appears to be hitting the fiberglass. Don't quite know how that could happen since nothing was loosened.
I have a 2010 CSC I call it squeaky. I spray it will kroil oil since CSC don't have any grease zerks on any part of the kit. When I spray it,it last about 2 months. I know what my next trike will not be :Shrug::Shrug::Shrug:
I found out that the problem is with the tension on the shock rod ends. CSC has been great about it. It is a warranteed item and they cover it for three yrs or 50,000 mile from date of purchase. They even called my installer before I could get back to him. Once I silicone sprayed the ends it disappeared. That may work for 100 miles, or a 1000 or who knows, but if it comes back too often I know it will be covered. That fact is reassuring.
I just had both rear tires off my CSC and noticed 4 grease zerts on each side. Mine is 08 model.
I'm told that the newer models do not have grease fittings. Might be good if they had kept them, although if the problem is with the shock rod end, fittings probably wouldn't help. I'm just glad I found the issue and that CSC will cover it.
Pmdurant1966
