Wind Deflection OFF Passenger
Oct 26, 2011
21
1
Newark, DE
I have not been a passenger on my Stallion, however my wife says the wind turbulents in the back are terrible. :AGGHH:
Has anyone out there found a solution for this problem? ThumbUp
The wind deflectors are great and I know as I was the test mule for the design. I also have a set of the soft side doors but, they have been in the trunk since using the wind deflectors as they work that good. If you look as the post I made on the wind deflectors, you will also see the pieces added to the windshield which also helps.
Tomg
I have the top and bottom Bakerbuilt wind deflectors on and they work good. I like the deflectors because when the temps are hot you can bring in more of the air and when it's cold you can block off the air. I had the same type of deflectors on my Goldwing and they worked good on it also.
Jerry 126
My wife and I found that the wind wings on the side of the windshield do not seem to help much for the passenger. I question anyone out there if there is a solid product that attaches to the top of the windshield that might deflect the air up?
Jerry 126
Check out this link: Laminar LLC - Products for Motorcycle Windshields and Fairings, Makers of the LIP & Touring LIP
When I bought my Stallion, it had one installed. The majority of my riding is solo, so I removed it. The previous owner swears by it, however. He and his wife did quite a bit of riding together. I will sell it to you if you're interested or if any other Stallion owners are interested. My PM address is pam1@midco.net
Daydreamer
Jerry 126
Jerry126 Take the side wind deflectors off the sides and place one at the top of the windshield. You will find that the wind is pushed higher up.
Hope this helps
edumou
