Motortrike airbags
Status
Not open for further replies.
The Wolf
TOI - Scotland
Mar 15, 2008
1,176
107
Livingston, Scotland
Jake
Do I have a leak?
When I adjust my airbags at the back for around 27lbs when I ride on my own. I leave the trike for around a couple of days and the air pressure dial is at zero and have to pump them up again.
Is this unusual for them to do this?
Lets hear your thoughts.
Thanks.
Yes my friend, sounds like you have a small leak somewhere. I leave mine a week and it might drop 2-3 pounds at most. I would check the air supply hose for tightness. I would find it hard to believe that the bag itself is leaking unless something has flown up and made a small puncture. Jake, just go over it very carefully and check the fittings on the line for looseness.. Good luck !;)
Jake..your trike is broke, it is how officially a piece of crap. Get rid of it and buy a new one. Or..take liquid soap and spray on your air lines to find the leak. It will bubble at the hole. Then fix it..
Thanks Jim I will get onto right away. George if I say I'm getting another trike Kathryn will have a fit:p
But there is an idea for another excursion abroad:cool:
Dam Wolf, George called your trike a pice of crap! I would chase him down , after you use his suggestion to fix your air line!
Status
teddycarnes
