Does anyone else have hard time finding neutral with bike running.
2012 Triglide.:Shrug:
How many miles do you have on trike. As they get more miles it will wear in. Putting a gear box oil in the transmission will help, I use 75-140 Amsoil some others on here have their favorite that work well also. You may also need the clutch adjusted. Good luck Dave
+1..A properly adjusted clutch make a huge difference finding Neutral.I've never had any problems with any of my Harley's once the clutch had been properly adjusted.
Plus I am not to happy with the Harley self adjusting primary shoe. Do not feel it adjusts the chain properly..
Yea I was looking at this one..I have used there evo model one for years and loved it..I agree 100% on the primary adjuster, to me it keeps the chain way tighter than it should be. The sad part is there are not many alternatives out there I would trust to replace it with right now. Hayden has come out with one but I won't run it until I see how well it holds up for others. Baker has come out with a manual adjustable replacement, problem is you either have to buy one of his $1,000+ primary covers to get the window for adjusting it and checking the adjustment, or remove your primary cover each time you want to adjust it or check the adjustment.
I will tell you one thing I put on the Clutch wiz and neutral goes in like butter too now..
Harleys have always been a pain in trying to find neutral. My 2007 is like that and so was my 2003, 2002, 2000, 1997, 1993, and 1992. Don't know why they can't correct that. Oh, and more miles on mine did NOT make it any easier.
The Clutchwiz is the cats azz, I love how easy the clutch pull is with it.
I believe if Harley would go the route that Baker uses in their trans, they could eliminate most all of their hard shifting & noise problems They now have a 7 speed out that drops all the ratios down including 1st gear.
I have never tried one of their boxes, but have talked to a few that have, & they all had high praise for them.
Why would Harley still be using straight cut gearing for one example? It isn't all just the clutch that makes neutral hard to hit ! If it was, why can you put Baker gears inside the Harley box, run Harley's clutch, & never have the problems with the Harley "clunk" or neutral problems ?? Also run quieter. Also without all the friction caused by straight cut gears ,,, less heat generated !
Just my opinion.............:Trike1:
Enjoy & ride Safe !!
Where do I get the clutch wiz for my 05 HD w/ Lehman? I am reading that it is worth the $.
