Fork seals 2010/1800gw
I am new at this so i hope this works. I just put the trike in the shop for cruise control problems resume button does not always resume. Also fork seals are leaking i only have 23,800 miles. It's a roadsmith with standard rake and full stretch. Any suggestions thanks to all shorty iba#35546.
The button probably just needs a good cleaning. My reverse was the same way. I forgot what spray I used but it was an electronic spray. Cleared the sticking problem up in a matter of minutes.
I an new at this so i hope this works. I just put the trike in the shop for cruse control problems resume button does not always resume. Also fork seals are leaking i only have 23,800 miles. It's a roadsmith with standard rake and full strech. Any sugestions thanks to all shorty iba#35546.
Not that it matters since you already put it in the shop but you might want to go out and buy a roll of 35 mm film. Sometimes just sliding some of that film in between the fork seal and the leg will clear the stuck on bug guts out so it will stop leaking.
