A friend recently told me about this and wanted to share it here......Looks like an excellent product. Check out the vid and decide for yourselves........Ride Safe.......
..::Rogue Chopper::Welcome::..
Correct me if I'm wrong, but couldn't a fella accomplish the same thing by cutting up an old oil filter base?
Phu Cat
I guess I missed something, how does it work?
The one benefit that I can see is that it helps purge as much dirty oil out of the system as possible and that's not a bad thing. Dirty, degraded oil can create acidic reactions that over the course of time can allow more wear on internal parts. Dirty oil can also eventually turn to sludge which can clog oil passages and in rare cases cause catastrophic engine failure.
Another thought I had is with oil cooler and thermostat equipped adapters you won't get all the old oil out. While your changing the oil the engine is cooling down which means the thermostat has closed. You then put new cool oil in which assures the thermostat stays closed. In the end the oil cooler lines and cooler it self are still full of old oil after the flush because the thermostat will not allow oil to circulate through the cooler.
FWIW I've worked on a neighbors 02 Road King which had 57,000 miles on it at the time. He changed the oil per recomendations and run a good synthetic oil, the engine was clean enough internally to almost eat off of. These folks who make things like clean oil change kits are just praying on peoples desire to pamper their toys. Lets face it almost everyone puts more love and care into their bike or trike that cost sometimes $10,000 or more less than the car they just drive and run through the local Jiffy Lube for the cheap oil change.
Another way of looking at it is that many folks buy all the cosmetic bells 'n whistles that realistically are only ornamental and can cost some serious bucks. If given the choice to buy an ornamental accessory or something like the Scavenger System that can possibly enhance engine performance and longevity, I know which one I'd choose
Long day here.......time to hit the hay.......Have a good one and Ride Safe ThumbUp
I agree people need to do what they feel is right or what makes them happy. I guess given my background with engines I have a hard time acepting the scavenger, it just makes me think of snake oil. It kind of burns me up that companies prey on peoples passion for taking good care of their toys with items that in the long run won't do much for the longevity of the engine. I've built, tuned and worked on race car engines costing upwards of $30,000+ and making 1,700 hp on a mild tune and never sweated the small amout of oil left behind from a change. I just built a 120" engine for my 06 Ultra, not worried in the least about the small amount of residual oil left behind from an oil change. I know some folks who have some serious $$ tied up in some pretty big HP motorcycle engines and they don't sweat the residual.
I'm a lucky fellow, your sleeping and I'm up all night at work:AGGHH:.
