I have a used after market wind shield, no idea of the brand. I have just about figured out the mounting using mostly flat stock. There won't be a bunch of room to adjust once it's mounted and there is not a wind tunnel within 150 miles of me. My front end has a pretty good rake, but I bought the bike used, so I don't know the degrees. I don't know if the shield should be vertical 90 degrees to the ground, at the same angle as the front forks, or some thing in the middle. Any info., guesses, or experiance will be very helpful.
Thanks for ypur time
