who makes a reverse conversion kit for '93 gl-1500se
Is the reverse on the Wing not working if you have an Aspy or SE? If you have an Interstate there is no reverse available.
There's a lever on the left side of the bike the you pull out slightly and up with the bike in neutral and then push the starter button to back up.
Okay, does the reverse work? Do you need technical help if the system is in place but not working?
Let me know so I can assist you.
jhlesher
