Which Trees
Status
Not open for further replies.
Jun 2, 2009
140
3
Camp Verde, AZ
Ok
I have decided on the Roadsmith conversion for my 02 Ultra with its big bag motor.
The question now is which raked trees to run:
1)Roadsmith 4 degree trees
2)ez-steer
3)CSC Power-trac
4) or some other set
Have read 4.5 degrees is max for a Harley, but CSC says their trees are 8 degrees for the Daytona Kit and others at 5.5 degrees.
I know there is someone smarter than I out there about this and can tell me which is the best way to go.
Mike
1852 WHAT DO YOU HAVE IN THIS BIG BAD MOTOR 140 FT PDS AT 3000 RPM ?? WHAT BRAND & SIZE CAMS , HEADS, PISTONS , COMPRESSION, THROTTLE BODY????? I HAVE A S&S 124 EVO MOTOR IN MY 98 ROAD GLIDE CHAMPION TRIKE, WHEN THE MOTOR WAS IN MY ELCTRA GLIDE 2 WHEELER IT DYNOED AT 137 FT PDS 127 HP. IF YOU BEET THE BIKE BAD IT WOULD SNAP THE BELT, I NEVER REALLY BEET THE TRIKE I THOUGHT IT WOULD BLOW THE REAR END OR THE BELT,& I DO NOT WANT TO CHANGE A BELT ON THE TRIKE. IT GOES REALLY GOOD & gets the same fuel mileage as my 03 road glide twin cam champion trike 30 - 34 . I HAVE THE CHAMPION EASY STEER ON BOTH OF MINE. THEY STEER GREAT.
Road Dog
It is a 2002 twin cam, with Jims stroker, pistons, jugs, s&s 585 grear drives, custom heads, fueling oil pump and lifters, race tunner.
Ya cant horse it too much, no power shifting, you are right about the belt, have 40,000 miles on the motor and the belt now, belt is a side car trike belt.
Running a d&d 2into1 pipe now, tunned for gas mileage now 127 ft lbs at 3000rpm flat line to 5200, has 98 ft lbs at 1800 rpm.
Has 108 hp, built it for torque not hp, really didn't care how much hp it made. Had to tune it down alittle gas prices were killing me, tunned for max smack was actually 138 ft lbs, but gas mileage was 32 mpg.
Heads like i said a custom, cumbustion chamber re-cut for this motor, little over 9.5 compression, stock intakes and really big exhaust.
Runs really good it is just a tractor, ride 2 up loaded down all the time used to pull a big trailor.
Still gets 42mpg if 65 or less the way it is tunned now.
I am sure it will make a nice trike.
Got it all gutted Ted. I have been down this road before.
Reksul, I ran the numbers on a rake calculator I have and the stock forks should not matter that much. The new trail with the TG trees, or a 1.5-inch extension would be around 3.9-or-so with the TG forks and around 4.05 with the stock 27.75 inch forks. The "old" FLH trail is 6 plus. For sure, since I have never had a raked trike, I will not be able to tell the difference. Likely as not, a few pounds of air in the front tire one-way-or-another would allow this variation anyway. I can always go back and add extensions if I want to. I am use to the stability of that 6.5-or-so trail and often tool down the road in a one-handed position, or just prop my hands up on top of the grips in cruise control....very casual, because the front end does not want to move that much. That's why the stupid thing is so hard to turn.....it dosen't want to! If the steering is as quick as I have heard some folks say it is, I will need to get use to it all over again.
VT it will still be stiff enough to lay your hands on the bars. You will love it. Ted
I need to back-up and apologize to Ultraboy Dave for caliing him Reksul Dave. Too many Dave's on this site. Ultraboy knows all about my last post here, so he did not need to see all that. I must have been looking and responding to something I thought I read from Reksul Dave. Things happen to your mental coordination skills when you get old enough for all your hair to fall out and become SS eligible. My wife has been trying to put me in a nursing home since I was 50.
Anyway...timgala....good to here there may not be a big difference in cruise mode.
Oh...I wanted to add a remark abour EZ-Steer vs. TG trees. I have never installed an EZ-Steer, but from what I can see and hear, they use a different style bearing, as well as other hardware, than stock HD guts. The TG trees just slip-on what is there now and use available HD parts. Material cost for the EZ-Steer at $1075 vs. TG trees at $400-or-so makes it a no-brainer for me and you have the added conveience of readily available parts if you need them quickly from any dealer scattered all across the country. The EZ-Steer may be a better looking set of trees as opposed to the TG cast units, but you are going to cover all that up with fairing anyway.
AND...I forgot to mention Champion will sell the fork extenders for $90 each, which is around 1/2 the price for TG forks and you can reuse your current fender mounting hardware. However, I think that if I wanted the extra length I would consider just going with the TG forks since you get a brand new set oil-charged and ready to go. If you had lots of mileage on your existing forks, this may be the best decision.
I think have the TG around is a great thing for us HD conversion people. If the HD part won't work at least it gives you a good idea on how to make something work. I can see a lot of adapting TG parts to our conversions if necessary. Ted
Thanks to Ultraboy, I don't see how there is much left to figure out on this particular conversion. There may be a few little quirks here-in-there that could differ among models and model years, but I can't see many that cannot be overcome. Dave went to the trouble of doing it to his own ride and then offering his honest opinion after some road testing. And....even steered us in the direction of where to find the parts. The vendor had to backorder one particular part for me, but for the cost, I am willing to wait a few more days before I have to look for another source. Hopefully, there won't be enough of us wanting to do this conversion and cause somebody to wonder "where all the TG trees are getting off to" and start jacking-up the price. I hope to be one of the first to get this done right behind Ultraboy and offer-up a good second opinion, especially on the retention of the stock-length forks. Mine is torn all to pieces and I am just waiting on the mail-man!
Dave, The obvious answer is build a trike from the rear end. Hang in there you'll catch up some day. I do every once in a while then it's right back down to being behind. Oh well it beats sitting around. Ted
TG Tree Conversion Update:
No...I am not normally this slow. I am still waiting on parts. I tore the ride down the day I ordered the parts in hopes of a quick ship, but the upper bracket had to be backordered on HD. I was told today the part is in-hand at the distributor and everything will ship today or Monday. My poor torn apart trike is lying out there looking like a piece of road kill and it's all I can do to keep the spiders and mud-daubers off it. And....I really hope I can remember where all this stuff goes when I do get the parts!
Hopefully...more next week.
Good Luck. I know how you feel. You prepare then get shot down with a delay. Ted
Status
snowking1979
