Wheels
Does anyone know if the bolt patterns are the same on the conversion kits as the factory H-D wheels. Just wondering if the wheels across the various manufacturers are interchangeable. i.e. I have an H-D with a Lehman kit but like some of the H-D factory wheels...will they fit?
All the trike manufacturers utilize a different bolt pattern and offset. You will have a large selection of wheels to choose from,regardless.
Lehman & Harley have the same bolt pattern 4X108 (4 1/4"). But they have different backspacing soooo..... Harley wheels won't fit under the fender of a Lehman and Lehman wheels rub the inside of the Harley fenders. There is about an inch and a half difference.
Champion has a bigger bolt pattern than older Lehman's 4X4 1/2". Lehman and Champion newer models will share the same Champion bolt pattern.
MoisesWedg
