wheel Traction and tire replacement
Mar 7, 2017
100
37
Bournville, OH
Hank
From watching YouTube I see more than just a few spinning there back tires, what kind of traction can I expect with Frankenstein trike conversion?
Should I go with larger tire size (Wider) Am I going to be playing slippery when wet, Will I need to replace tires more than once a season ?
Thanks for any replies ahead of time
Hank
Hank
You are seeing people trying to burn up the tires...Also the wider the tire the more flotation your going to get...Be it a car 'trike 'or truck..And about replacing tires more than once a season... Depends on how many miles you do in a season.. 45/50 K a season yes you will need tires. 5/10 K No....
Unless your building a hot rod spinning your back tires shouldn't be a big problem, Frankenstein like other kits come with the right size tires.
Once in a while I get surprised when turning a sharp corner on take off but tire spin is short lived, Besides I cant afford to beat up my scooter by placing such stress on components.
Wide tires look cool but may actually cause you to loose traction in certain situations because the tend to float, especially in a corner where there is sand, water puddles etc. on the road?
Trike tires are deliberately run at a lower inflation rate than you would run that tire on a car, It is actually part of your suspension. Running a tire at full inflation will be a real stiff ride kinda like a ridged frame chopper.
Watch for cupping on the tire, invest in a tread gauge and trust in the folks that designed your kit.
frankenstein
Hank
have 30,000 on my frankenstein kit and have hardly worn the tires- 24 pounds of air
traction on road gravel and sand?
I have always had great worries while ride on 2 wheels about sand and gravel in a curve, I laid a bike down back when I was a young man going around a curve, it was in the shadows going into the curve, front tire went out from under me, I didn't have clue how to stay upright, now days I watch for sand and gravel when I am on curvy roads, I still cant see anything when riding into a shadow from facing full sun. How much does having 3 wheels on ground help, I know common sense is a bog factor also, so I wont be racing thru any curves ( I don't think)
Trike
In my opinion. Riding a trike is the best experience you will ever have. Sand gravel ext. in corners mean nothing. Driving in heavy traffic is all of a sudden fun as you can zip througH it witHout the fear of sliding out on somethIng on the road. Your passenger will feel safer. Just too much fun to keep listing
MagicEagletrike
