What would a B Head job do for performance?
Nov 1, 2011
110
Rockwall, TX
John
What could I expect in terms of hp and torque if I did a B Head job to my 2010 TG? Any suggestions of where to get it done and the cost? My signature has the modifations on my TG. Thanks
Re: What would a B Head job do for perfarmance?
I'm thinkin the head manufacturer could tell ya best when they know what mods you already have.
Phu Cat
There's a joke in there, but........
Just a fyi about these dyno sheets you will look at.
1) Each dyno works differently some are happier then others to give high power readings.
2) Not all dyno operators tune the same
3) With a trike you can expect to loose 5-10% additional power because of the trike rear end compared to a 2 wheel bike on a dyno with the same engine package.
4) Each engine built that are same cubic inch, will not always produce the same numbers
IMO I wouldn't spend a whole lot of money on head work if your keeping the SE255's, you can't bump the compression much more than it is already without making it more particular with fuel quality and the cams just won't take advantage of the upper RPM range of the heads. Now if your looking to do cams along with head work and maybe a bump in displacement you have a whole wide range of choices you can make.
Wife has the FuelMoto 107" build,woods555 cams,and "B"head job.
We both think its a tremendous improvement over stock 103"
Thanks for all your help. When the warranty is out I'll put a 120R in it. Until then I'll just put miles on it. Thanks again!!
Don't know about the trike, but a Head Job.....
never mind, I don't want to get banned :laugh: :laugh: :laugh:
Keep the S&S 124" in mind. Roughly the same price and you get a better flywheel assembly that doesnt need welding
:Agree: Its a little more money but heck its well spent, I love crate engine wars the big winner is the consumer.
nmbr1soonerfan
