What a Harley BCM Does
Jack Klarich
Gold Member
Oct 11, 2016
18,135
15,206
Jacksonville, FL
Jack
Here is a good read and info on your BCM.
The BCM was introduced on MY2011 Softails. As of 2014 it is on all Harleys except for Street and V-Rod. It is the successor to the TSM/TSSM (turn signal and security module).
There are six different varities of BCM in existence today on commerically available bikes (not counting changes from model year to model year). It comes in two "orientations". One orientation ("Y-Axis") is for softail, the other orientation ("X-Axis") is for all other vehicles. Then there are 3 security types. One without security/fob support, one with security/fob support for Japan only, and one with security/fob support for the rest of the world (odd Japan wireless frequency regulation no other country has - automotive typically has the same difference). So between the 2 orientations and the 3 security versions, there are 6 total. A BCM on softail cannot be used with any other family. Part numbers vary from model year to model year.
It is the "network master" and tells the other modules when to talk and when to be silent.
It also controls the vehicle mode. Whether your vehicle has an ignition switch with IGN/OFF/ACCY right on it or is the "keyless" variety, the BCM tells everyone else what mode you're in - OFF, accessory, or ignition, and also communicates when the starter is cranking. It also cuts engine and pump power if the kill switch is pressed or it tips over.
It powers the starter solenoid, and as such controls the starter interlock - making sure you're not in gear (or the clutch is in).
It powers the fuel pump, and can cut of fuel in the event of a tip. It will prevent starting and disable the fuel pump if there is a security violation (NOTE: for safety reasons, it will not do this is the vehicle is already running and moving).
In combination with the ECM, it powers the engine coils and the fuel injectors, so it can cut power to the engine, but does not play a role in throttle control.
It DOES contain an internal accelerometer. It uses this both to detect if the vehicle is being disturbed for security, and to detect if the vehicle is tipped over. As noted, it DOES NOT work for Trike. On factory Trikes MY18 and prior, there is an additional Bank Angle Sensor (BAS) that tells the BCM if the trike is tipped or not. For MY19 and later factory trikes - it's actually the ABS module (which in turn is talking to an inertial measurment unit [IMU] ) that tells the BCM how much the bike is leaning. It is much more accurate than the internal sensor. I highly recommend against turning a vehicle into a trike or adding a sidecar for this reason. At the very least, if you do, you need to properly install a BAS and take it to a dealer and have them change the BCM settings to the trike/sidecar configuration.
It talks to the ABS module, but it does not intervene in any braking events. In some later model vehicles, it uses information from the ABS unit to light the brake lamp.
It controls all of the lighting on the vehicle (except aux/fog lights on older vehicles and ones installed via kits). There are no lighting fuses, the BCM detects if there's an issue and shuts off the power if there is.
It also controls the security system, talks to the fobs and siren (if installed) and will flash the turn signals, disable the fuel pump and coils if there is a security violation.
It also powers the accessory connector.
If you have a CVO MY16 or later, the BCM also controls the power locks.
Note that you cannot swap/replace a BCM without the dealer (or at least a dealer tool). The ECM knows exactly which BCM it is talking to and if it senses a different BCM, it will assume something on the bike is stolen and not allow the engine to run and will also tell the BCM to turn off the fuel pump and not power the coils/injectors. So do not swap a BCM on your own (unless you have and know how to use the dealer tool - and I'm not talking about the generic diagnostic tools you can get online, I'm talking the actual H-D dealer tool. The generic diagnostic tools can be used to read trouble codes but cannot be used for replacing and configuring electronic units). That being said, if you ever need to find a replacement BCM, a new BCM can replace an older BCM of the same type - but with few exceptions, you cannot replace a newer BCM with an older one. Additionally, each BCM has to be configured for the specific set of features on that bike. You cannot swap a softail BCM with a BCM from any other family and vice-versa.
Great read Jack thank you
Hi Jack,
Thanks for this post. I hope you don’t mind, I have some questions.
Yesterday I went for a short ride. About half way home I noticed that my security light was on. It stayed on the whole way home and comes on and stays on whenever I turn on my trike. I pulled two codes, b2223 and u0100. B2223 seems to be a rear brake switch problem. I have just this week had my cracked fender replaced (long story) so I was thinking maybe that code has something to do with that. All lights are working properly, blinkers and brake lights. U0100 sounds like a scary problem. I’m not very technically minded but I read that my bike could shut itself down. Is this right?
Also, at the start of my ride, I hit a severe dip in the road. My bike tipped to the right suddenly. Scared the life out of me but I did not notice my left tire leave the ground and I did not lose control. Could this u0100 code have occurred as a result of this? Maybe a tip sensor or something?
I’m going to take my Tri in to Harley to be checked out, I just would like to have as much info as possible before I do. Thanks for your time.
Hi Jack,
Hi Carol, Your rear brake light switch is seeing low battery voltage and is going to fail. The U codes are lost communication with the BCM and or ECM. It is possible with the can bus system for an engine to shut down. I would have a dealer look at this problem. Harley goofed up IMO placing the rear brake switch too close to the front exhaust. My 17 Freewheeler is having problems with that switch, I have ESP so I will take mine in. Good Luck with yours and check back in;)
Do not clear the codes, give the techs a chance to look at all of them. Typically when your security light is on the cruise and brake lights do not work.
Vulcan900
