Were can i find blueprint?
Jul 22, 2018
4
Dingle
Hi!
Im a new come in the bike world, but have built many cars. Now im going to try build a trike based on volvo b23 engine center placed. I know it will not be easy to build but im will try. Is there any one who could help me to find blueprints for the frame?
Niklas, I can't help you, but I can offer you a big Texas welcome. When you get started on your trike build, be sure to post picutres.
welcome.....
best wishes finding a blue print
but there are frame alignment "prints" for straightening a frame after a crash...
not very detailed like what you want
Start to change my mind in engine type? Maybe I will use some older engine like B19 or B20 volvo engine its not so much electric wiering and not that big engine.
Stage 1: Build the lowerframe in woodplank.
Stage 2: mark out place for engine holders.
Stage 3: Get rear axel and gearbox and build the backframe.
Think that will bee a good start šŸ˜‰
Volvos, Saabs, and trikes
Hello Niklas,
You have asked about two vehicles that I know well, Volvos and trikes. I love my Volvos, I have four and a guest PV544 that I am working on for a friend. I also have a VW trike that has carried me several thousand miles without problems. So, when I saw your post I had to comment.
I cannot provide blueprints. If any blueprints have been drawn, you will probably find them in Sweden. Ten or more years ago there were a few pictures of a beautiful B18 build. It was a very clean build and it just looked "right". I don't know if that translates well. It was beautiful to a mechanically inclined eye. I tried to find it again just now to give you a link but could not find it.
However, I did find another Volvo powered trike. It is a redblock OHC, probably a B19, maybe a B200? The single SU manifold was not sold in the USA so I don't really know what engines it came on. He has mounted it upright, like a push rod engine. Notice the triangulated engine cradle this young man built:
https://www.youtube.com/watch?v=_fznJKe80_A
He used tubes to make the grille/radiator with no fan at all. That might work in Sweden. I can promise you that it would not last one summer day in Texas. ;-)
He has a website that features his V8 trike build. He also has a section devoted to his first build with the red block. I am not certain what he means by, "The bike was just about movable...". Perhaps he had handling problems with the bike? Probably so, that rear axle is solidly mounted.
http://neverlessdesign.com/projectrhisonda.html
Follow the "journal" link from that page to the build sequence. He has pencil drawings and lots of photos. You might want to contact him to see if he can offer any advice. My advice? Add real suspension at both ends, a real radiator, and get that muffler out of the breeze.
Push rod or OHC engine?
The B18 engines are plentiful and cheap. The B4, B14, and B16 engines are for collectors and everyone else wants the B20 for the extra power. So B18 engines end up as garage decoration. Hell, I have two of them in storage myself. You are bound to find one free or nearly free in Sweden. New timing gears, rings, inserts and valve guides will allow any Volvo push rod engine to run another 100K miles worry free. Well, the cams do go flat after about 200K miles but what is boy to do? :)
If you start with a slant engine you will have to mount it upright so you have somewhere to put your feet without burning your leg. That requires modifying the oil pan and pick up tube.
The OHC red blocks are much more plentiful than the push rod engines now. They did not end production on those until the 90's. No push rod engine has been produced since 1975.
If newer technology and more power are your goals, the B23 is the choice. If simplicity is the goal, the B18/M40 package is the ticket.
One more thing. Have you considered the Ford V4 engine that Saab used in the late 60's? I don't know how numerous they are in Sweden but there are bound to be more there than here. That is a very compact engine making about 65HP in stock trim. A complete Saab running gear would make a lightweight reverse trike. Just thinking out loud...
I also think the Saab v4 of the late 60s would be an interesting choice for power. I looked for an old turtleback for my project (didn't find one). The V4 is tiny but mighty. The transmission doesn't add any length, and it's front wheel drive -- perfect for a reverse trike.
BrooksBunk
