We need to talk about oil.
MDO
Oct 11, 2017
5,099
3,124
St. Louis, MO
Michael
I have a 2017 FW. At my 1,000 service in CA, the dealer put in HD Syn 3 & on my trip back to St. Louis it felt cooler & shifted better. At 3,750 miles, I changed to Lucas 20W-50 full synthetic high performance motorcycle oil in all 3 holes & the improvement in shifting was immediate. Also, the engine operating temperatures dropped about 20 degrees.
I am glad that I made the switch & I like having the same oil everywhere. I am using the HD 5 micron oil filter. Looking at the specs, it's 1 of the better ones out there IMO.
Here is what confuses me. I don't know if the notion of running the same fluid in all 3 holes just started with the new M8, but the correct procedure for what oil to use where varies from dealer to dealer & even at the same dealership, it depends on who you ask.
I would think that as a company with a new engine out, there would be some consensus on the best procedure, but that's not the case.
1 other oil item of note for new M8 owners. when I had the 1,000 mile service done at the dealer I purchased my FW from, the tech noted it was nearly a quart low on engine oil. He said this is very common in their brief experience with the new engines & mentioned that the MoCo had been getting the same comments. On my 2,000 trip home, the oil was down maybe 4-5 ounces, not enough to worry about, so the oil usage slows/stops after break-in, or at least mine did.
So, what are you all using in all 3 fluid holes & why. Is it cost, availability or both. Also what filter are you using. I wanted a Mobil 1 (used on my cars for years) oil filter for motorcycles, but could not find them locally & after research, stuck with the Harley 5 micron filter from the dealer. They seem to be well made.
In the area of full disclosure, my son has some connections & does work with Lucas Oil & he got them to send me 3 cases of their oil. I may not have ever tried it, due to the cost, but I'm glad I did. It's comparable to Mobil 1 V-twin oil, price wise, if you shop around.
I do not sell Lucas Oil or any other oil.
He also has K&N connections, and I'm working on getting some of their KN-171 oil filters. If I ever do, I will let you know what I think.
There have be guys using one oil in all the holes for years so it's not new news. When I had a Harley my personal choice was a different oil for each hole. But it really was a pain. It's so much easier to keep one oil on hand only. And an oil you can pick up at any auto parts house is even better. Todays oils are so much better than just 15 years ago so it almost doesn't matter which oil you use anymore. The key there is almost. Use the correct oil for your engine and you are good for the most part. Harley and their three different holes will always cause people to have very different opinions on what to use. I think Harley did make a corporate statement that Sync3 could be used in all 3 holes. So if they did then they also said any equal oil could as well. I'm just not positive if they made that statement or if it has been the dealers which would make it another opinion instead. One thing to avoid are oils with friction modifiers though for those that only have one hole. So be careful there. Your best bet is to look at the owners manual.:rftm::AllGood::wave4:
I use Sync 3 in all 3 holes, And the standard Harley oil filter, 45 k on my 11 T/G And just under 4k on my 17 T/G....With out any problems with excessive heat.. [I do know i'm sitting on top of an air cooled engine] Or shifting problems...Its not a car with a firewall and insulation between my precious parts and the engine....:Shrug:
2014 32k miles
HD Syn 3 in motor
HD Formula+ in primary
Bel-Ray 85W-140 in transmission
Recently got introduced to this company and may try them out > http://stores.buyschaefferoil.com/categories/motor-oil/schaeffer-harley-oil.html
I interviewed many Dealerships and you will NEVER find any consensus on oils. Everyone has their favorites. Every Dealer has lots of non-HD brand oils in the back to satisfy their customers oil requirements.
Bob :Dorag:
It's in the manual that you can use Syn3. It's actually their 1st recommendation.
2014 32k miles
HD Syn 3 in motor
Bob :Dorag:
I looked at the Schaeffer Oil website you linked to & I personally have never heard of them & I tried to find a data sheet on their website & couldn't.
I read a lot & the thing that I picked up on in reading independent oil comparisons is that specific motorcycle oil has a much higher zinc content(ZPD) that regular car motor oils.
An example of this is Mobil 1 full synthetic oil (15w50) compared to Mobil 1 V-twin (20w50) motorcycle specific oil. Both these oils are very good at what they are intended for.The motorcycle specific oil has nearly double the Zinc that the car oil does.
Reading on motorcycle forums, many bikers use the Mobil 1 oil because its a good oil & you can get a 5 quart jug at Walmart for $23
Zinc is added to the oil to decrease wear. This is most likely due to the fact that many motorcycle engines can run at double the RPM that a normal car engine runs at.
Oil is like a religion to alot of folks
I have always run dino oil til now
http://www.quicksilver-products.com/street/motorcycle/engine-oils/full-synthetic-motorcycle-oil/
I am running this oil with good results
I run Lucas gaer oil in the tranny
Formula + in the primary\An HD filter up front
I cannot find any filter supplier to go on record stating their filters are 5 microns
I have always run HD dino oil in ALL my other bikes
Seems this Quicksilver oil tests as good as Mobil1 HMMMMM
Get it @ Walmart for 6bucks a quart
Thanks Jack. That's good to know info on the Quicksilver oil in case I loose my Lucas Oil connection.
On the 5 micron filters, the HD is the only 1 I know of & they say it on the box. I read who makes them for HD, but can't remember.
If it is as good as Mobil 1, why would pay more for it ??
Mobil 1 = 5 qt's for $23.00
Quicksilver = 5 qt's cost $30.00
Thanks Jack. That's good to know info on the Quicksilver oil in case I use my Lucas Oil connection.
Champion Labs had the last contract for the filters that I remember
They are big in the filter bussiness making lots of other filters also;)
Did I say how much I hate oil threads?
I do
Like I said before Oil is like a religion
Go with what makes you feel comfortable
Most modern day oils ( synthetics) are manufactured in labs
They are made to a high standard with chemical altered additive packages
Some better some cheaper
It is your ride You decide how much you will pay
The only thing I stick with OEM is a HD filter
I have yet to find any filter that can measure down ( according to HD) 5 microns
You need to remember you are comparing a Mobil 1 car oil to a Quicksilver motorcycle specific oil.
I do
Don't like oil threads! It was you who told me to start this.
OOPS, I dared you:p
I think Tynker was talking about Mobil1 motorcycle oil
It is a good oil
I just dont like it
Too many TC owners have some top end noise with this oil, my brother included
Any modern day full synthetic is OKIMO
I chose Quicksilver
I have seen a Blackstone Lab test on it and it faired good
After the test the zinc and other GOOD additives held up as good as Mobil 1
Not bad IMO
OOPS, I dared you:p
It is a good oil
I just dont like it
I chose Quicksilver
Not bad IMO
I may give Quicksilver a try. When I get down to my last 4 quarts of Lucas, I may keep them for the transmission & primary & put Quicksilver in the motor. I'm kind of strange in that I plan things out, like what battery I will get for a replacement & what tire I will get, then when the time comes, I just look at my list & I don't have to shop & compare.
Planning ahead, I like that;)
Have you tried gear oil in your tranny? If not you should try it
In almost every HD gear box I have had it makes for better shifting
More cushion for the gears and bearings
The Lucas Oil I'm using is doing great for me, but I'll look into it.
What weight gear oil do you use?
I see some are 70w-90 and some are 90w-140
Gear oil is not my strong point. Lucas makes a dedicated oil for the differential & tranny.
I have heard good reviews on Mobil 1 & Valvoline full synthetic gear oil.
I also read the gear/tranny fluid is under low stress & can take 10,000 mile change intervals.
Try Redline heavy with shock proof,
Mobil 1 is good also
I am currently running Lucas 75-145 synthetic
The Redline cuts down the clunk
Plus it is designed to cling to the gears better
You can view on the site what a burned up tranny looks like
You will see shifter forks burned blue
Spectro makes a Platinum 6 Speed gear oil
Baker the leader in the Tranny industry ships their trannys with a quart of this lube
I have run this in my 07 Dyna,it was a very good lube
Much like most oil threads you will see many likes
IMO your ride you decide
I just hate seeing motor oil in a gear box;)
You have me convinced. I will keep the Lucas 20W/50 for the motor. Hell, I might as well try their tranny fluid. How long of a change interval are you using?
Those 2 reasons are why I liked Redline while I had a Harley. You had to listen extremely close to tell any difference in the clunk though. It was slightly better. I also like gear oil for gears. But Harley says motor oil is fine and they have to warranty their drivetrains.:Shrug: But what happens after the warranty period? It's on you then so choose wisely.;)
An oil thread! :)
To delve deeper, for those interested...
What weight oil is "20-50"? (no, it is not 20 weight when cold and 50 weight when hot)
Can someone look at their M8 Owners manual and see if they have a page that reads similar to the one below?
An oil thread! :)
Same chart.... In my manual...2017 T/G, Except no 10/40 listing In place of the 10/40 is 20/50 full Synthetic.. ......
Thank you. Was not sure if HD was still saying it was best to run straight 50 in temps higher than 60* and straight 60 in temps higher than 80*.
(not that you will damage the engine running a thinner oil, like 20W50, in hotter temps....it's just not the best practice)
Table 1. Recommended Engine Oils
TYPE​
VISCOSITY​
RATING​
LOWEST AMBIENT
TEMPERATURE​
COLD-WEATHER STARTS BELOW
50 °F (10 °C)​
Screamin' Eagle SYN3 Full Synthetic Motorcycle Lubricant
SAE 20W50
HD 360
Above -1 °C (30.2 °F)
Excellent
Genuine Harley-Davidson H-D 360 Motorcycle Oil
SAE 20W50
HD 360
Above 4 °C (39.2 °F)
Good
SAE 50
HD 360
Above 16 °C (60.8 °F)
Poor
SAE 60
HD 360
Above 27 °C (80.6 °F)
Poor
This is from the 2017 Freewheeler manual. For the new M8, the MOCO likes 20w-50
I knew people would like my oil thread.
TYPE​
VISCOSITY​
RATING​
LOWEST AMBIENT
TEMPERATURE​
50 °F (10 °C)​
SAE 20W50
HD 360
Excellent
SAE 20W50
HD 360
Good
SAE 50
HD 360
Poor
SAE 60
HD 360
Poor
Not sure how you're coming to the conclusion your stated.
I am reading the chart you posted and seeing that if the lowest temp you ride in is above 60 and below 80, the recommended oil is SAE 50, and if the lowest temp you ride in is above 80, the recommended oil is SAE 60.
The Excellent, Good, Poor ratings are referring only to "Cold Weather Starting" below 50.
The reason the temps are there is that different weight oils are ideal for different temps....otherwise, why even have a chart...they would just say that 20W-50 is the recommended oil.
ertodd01
