I have a 2019 tri glide ultra. My engine and temp lights went on. After starting the bike and letting idle, the temperature got to 277 degrees. The water pump, coolant and hoses felt cold. Before I get a new pump, I want to check the voltage to the pump. With the ignition on, at the left prong (the cooling relay power circuit) I got 12.02 volts. At the center prong ( cooling pump control circuit ) I got 1.09 volts. Can someone tell me if these readings are correct. If not what would be my next step? Thanks in advance.
