I know firsthand how difficult it can be paying the big money and buying one
of these sight unseen, but thankfully it worked out well for me!
Cosmetically it is far above average the only thing other than the usual few chips on
the fenders was a rear speaker grille that needed replaced (torn) harley makes these
cheaply (on purpose I think) all it takes is one elbow in there and it's torn, got a new one coming.
Other than that, she looks pretty good.
Oil was filthy and up to full mark, I changed out and now 3/4 or so.
Trans was filthy black, changed and put fresh Mobil 1 75W90 she seems to shift fine
No coolant in reserve tank, added topped off to cold mark.
Parking brake fine, I wont use it anyway
Tires were 39 front, 38 PSI IN REAR!, I went with 36 front 26 rear as Harley recommends
NO AIR IN REAR SHOCKS seems like PO didnt know where (or if) to put in air I filled to 35 PSI
(two riders)
Cleaned it up, took it out rides perfectly motor is great!
He had the idle mgt system disabled, I enabled it motor needs every bit to run as cool as possible
Need to get used to taking off with EIMS enabled but not that big of deal
I got lucky, what do you think?
(two riders)
