U-Joint Part#s for 2008 and up Honda/Roadsmith Conversion
lgjhn
200+ Posts
Jun 15, 2013
211
99
SW Louisiana
Larry
Hi All.
I'm looking for the U-joint part#s for the 2008 and up Honda Roadsmith conversion with the 6.75" Ford differential.
I've found Part# 5-153X (grease-able) for the front, but cannot find any part#s for the rear one at all.
Thanks,
LJ
UPDATE: I found what I was looking for. Please kindly disregard this request/post. Thanks. LJ
You should be able to download a owners manual from Roadsmith. It should list the part numbers for the driveline.
Yes, download the manual. The Spicer #'s ; front is 5-153X the rear is 5-1201X. The rear part number has been replaced with a Dana Spicer 5-7439X. NAPA has a comparable joint that can be greased. The issue, the rear yoke blocks the fitting. I suggest changing out the straight zerk fitting to a 45 degree. Please note, the rear joint has two different size caps. The larger caps fit the differential yoke.
mudrock
