Tuners
Depends on how deep you want to get into it!
Simplicity way: Xtreme enrichment device #FL-XIED-10
O2 sencers, along with Arlen Ness Big Sucker air box, good flowing mufflers, (with or without noise) and the cat removed, will do you justice with out the expence or aggravation. The best part it's all plug and play, except for the cat. Good luck and be safe.
Yea, looking for basic stage 1
Duals
Mufflers - Not loud but a little louder than fac just want the deep rumble
Air filter
tuner
My question is on the Fac pipes it has the OS2 but what about when I change them to duals? Will they have it? Will I need to tap and install it? Or just not need it?
You should have factory duals with 2 - O2 sencers. Really don't understand your question :Shrug:
Sorry,
Yea the fac exhaust has 2. When I replace the fac exhaust with say V&H or Reinhart, will they have the OS2 as well or not?
Most after mkt headers come with the O2 bungs. But you don't need after mkt headers .No performance value to be felt. JMO
If you want to spend the $ that's your privledge. As far as the hairball is concerned, there are threads on this forum on there removal process.
You are at the right place for help.
If you are able to decat the pipes on there now that will save you some money there and add your mufflers to that.
I think the one thing that might help is to talk to your local tuner and see what they are comfortable with and talk to more than one if possible ,and move forward from there.
I have seen places that have the fac. Exhaust with the cat already out and just exchange... I do not have a local tuner, I "Assumed" you get the tuner and select the programming that matches your setup and download it
Yes there are places you can do that.
Picking a tuner is something everyone has to do there homework on , and most everyone has a opinion on
some who like to tune themselves and some who leave it to someone who does it for a living. Even if you don't have a tuner in your area call the closest one to you and talk to them.
Fuzzy,
I would be interested in the PV, but I can't seem to locate the For Sale area. Sorry to hear that you are losing the TriG.
Marks2024
