I have a 2024 Tri Glide Ultra and is it normal to have to slam the door a bit for the door to properly close and latch. I noticed when I didn’t it would open while I was riding.
DWhen properly adjusted it does not need to be slammed to stay shut. Use a couple of open end wrenches, and loosen the locknut, then adjust how far the striker protrudes so that it securely latches without slamming, then tighten locknut.
Was suggested by the dealership to slam it. After it fell open twice, I dosed it with a little spray lube and I now close it by applying pressure to the door in the closed position. Much betterI have a 2024 Tri Glide Ultra and is it normal to have to slam the door a bit for the door to properly close and latch. I noticed when I didn’t it would open while I was riding.
