Trunk door
Mine has popped open a couple times, even though it was locked. I think railroad tracks got me. To retain the door closed, I used a small bungee cord. I looped one end around one of the bolts that attach the tour pack in the top of the trunk compartment. I wasn't very imaginative on how to attach it to the door, but used the hook end of another bungee to make an attachment point. I tied a knot in one end of the bungee until I had the tension about right. It now holds the door shut even if the latch pops open. Really easy to attach and detach. Not elegant, but it works. Pardon the dust - I live on a gravel road.
I liked this idea. So I put it together today. My rear door fell open shortly after purchased. I lubed the push button and it never happened again. However, It was now embedded in my brain that it could fall open again at some point. so this eased my mind for sure. Thanks for the Idea!
Had to cut bungie to make customize fit. Use a small zip tie on the end of the bungie cord to prevent spring from coming off.
Don't slam the door. Lots of plastic in the lock housing that can suffer from repeated slamming. Check adjustment. Biggest thing I've noticed is you can close door and hear it click but if you push in again and compress the weather stripping you can feel and hear latch totally engage. I got tired of leaving fingerprints on the clean door so I bought a stick on caliper insert medallion and placed it appropriately and use it to push on to seat the latch fully.
This seems what caused the door problem on my neighbor's 2016 Tri. We'll just finish installing the brake pads and black rhino wheels on his Colorado before we check his Tri. Hope it's just the spring.
I'm not one for slamming anything because of the consequences. I total agree with you on that. Mine fell open that one time and I probably had it 3 weeks at the time. I lubed the push button and that fixed it up till this point in time. I just added the spring/bungie for my own mental state of mind. And it was fun installing it.
I lube ours every spring no issues 09'. You have to maintain or have someone maintain it easy. Remember if it's a Harley you must pay attention or they will get your attention $$$$. Ride safe Fred
Happened to my wife on her 2011 Tri when it was new a few times. As Fred said, lubricate it once in a while. The button gets kind of sluggish or sticky feeling and it does not latch good. A shot of WD40 or similar works very well. Happened to me on my 2019 Tri last weekend, got the tool roll out and sprayed mine and hers. Also we pull the retaining cables to the center of the trunk before closing, other wise they get pinched a lot. I like Rhinos idea with the bungee cord.
We always lock ours and they have still popped open locked. Less than a handful but still not something I want to worry about and the lube works.
What do you use for lube?
Arnie KY on your back door ???? Do you put it in the hole or on the think that sticks out ?????
Haha the outie. But I was serious, I have used that plus I have used dielectric grease, & silicone o ring lube. all worked the same with ky lasting longer. try it, just a dab will do it
Desertgecko
