Trouble with my Rewaco HS4. Cant get the ignition lights to come up .
HI all.
wonder if someone can help me. I have a rewaco 2005 HS4 but Im having ignition trouble. Went to start it the other day and nothing, checked the obvious battery connections checked voltage to ignition switch which seems ok?. Then I turned the key again and it flicked into life then went out again so no start. Ive change the ignition switch and the wiring looks ok , Im about to change all the relays incase its that but I can get hold of the ignition one at the end, does anyone know where I can get one. There are no markings on the bugger so i cant track one down. There are 3 identical ones and the last one which is the one I can get hold of.
HI all.
