Trike Wobbly
I cant tell if is coming from the front are rear It does it when I hit bump, not hitting a bump and yesterday it did going down the road
Is this something new thats going on.:Shrug:.. Have you checked the air pressures in the tires.. 36 front... The back should be somewhere between 23 and 28.. The air shocks will be something you'll have to experiment with. That said this is if it didn't just start suddenly...:Shrug:
Capt. Bob Might have hit on a possibility... Check your tie link bolts on the top front head... Two 9/16 bolts.. They've been known to loosen/fall out and in my case also shear off. Worth a look see...:Shrug:
PSI and tire run out, you can check both easy. Poor mans style jack up one wheel set a bottle down next to tire, rotate tire look for wobble, bike needs to be in neutral
Joe Henry
