trike and bic hauling
Dec 7, 2008
21
Manitoba ,Canada
Venture1
Got a question has anyone had any experience or heard of a unit called
a Idahoe Tote , it is used for transporting a bic or trike behind a 5th wheel
camper, need some pros and cons on this unit:Bow Down:
I've seen a few behind RV's. buses and campers on there way to and from Strugis. Never noticed anything about them that would cause me any concern. Just keep in mind that they add to the length of the vehicle and there are limits on how long you can be(65').
Have one attached to my 37 foot 5th wheel.Also have the rampage lift afixed to the tote. Took it to Texas in 2010 Had no problems backing it into camping sites or unloading and loading. It does what it is supposed to do.The only thing I heard is in Ca.you might get stopped. But this is not a trailer so it doesn't need plates. It is attached by a reciever bracket to the two main frames on the trailer then you may disconnect by undoing two 3/4 grade 8 bolts,lower the dolly wheel and push it around to where you need it.
Tozbro
