Trailer Store Batwing and Freewheeler.
Mar 6, 2025
109
268
Jackson, MI
Dave
So the Trailer Store batwing fairing mounts on the detachable for mounts for the HD fairing. About every 3rd ride, I noticed that the fairing was raising up on the fork mount bushings. I'd put it back down where it belonged, and then it would rise up again after a few rides.
I was afraid that there was a possibility that the fairing could rise up enough to actually swing forward out of the top grommet, besides the fact that it shouldn't move. Since I had some 1/8 x 1 stainless flat laying around, I made a couple of brackets to keep the fairing in place. I drilled for the 5/16 stud with the acorn nut, and I drilled a 1/4 inch hole to attach the bracket to the fairing mount. I added a rubber grommet just because I knew the bracket wasn't going to sit perfectly flat, and I was hoping it would take up some space between the bracket and the fairing mount and add some cushion also. I have no idea what kind of stainless steel they used for the brackets, but I finally had to go to the machinist's chest and find a carbide drill to drill them !
The next thing I noticed was that you could pull the top of the windshield, and the outer fairing would move quite a bit. Two screws hold the inner and outer fairing together, as well as the windshield screws. The fairing was moving in the headlight area so I drilled 2 holes under the fairing in the headlight cutout area and added a couple screws. It doesn't move anymore. I had to remove one speaker to put nuts and washers on the bolts I used, but that's pretty easy.
I didn't get a pic of that modification, but I have pics of the brackets . I need to fine-tune them, but I must mow tomorrow as we're gone for a month on Tuesday. Trike, Toyhauler and camping and beer money :)
Going to try the back of the dragon on the trike ! We did it last summer on the 2 wheeler.
Dave Jackson, Michigan
Very ingenious. But what sucks is that it should have been good to go right from the beginning but then you ended up having to make modifications to cover the shortcomings. Glad you were able to come up with a solution.
Well I am not blaming the Trailer Store although maybe they need to do something differently so the fairing cant move . They also need more screws holding the inner and outer together. I think I have it all set now and the trip will tell me more.
Dave Jackson,MI
dyno56ca
