Me again!!
I have a 2003 1800 that was converted to trike in 2010 by Champion.:clapping: I am the third owner. I had a trailer that had the flat 5 connector that worked great behind the trike, all lights worked perfect.
Well I just bought a new trailer that uses a flat 4 connector. I bought a Hopkins converter from 5 to 4 and installed on the trike. When I first tested the lights hooked up to the trike, the signals would only work with the brake lights on?? :blush: :blush:
After a couple days of trouble shooting I find out that with the bike running everything works fine!!
So its a low voltage issue. :cxtv: I have an trailer isolator on my 99 Valkyrie, and was wondering if the trike might have one and where it might be located. :xzqxz: I am assuming that it does not due to low voltage. If I install the isolator will it work with the converter.
I am just full of questions!!!
