Tour Pak hinges
Status
Not open for further replies.
Apr 24, 2008
734
23
Central PA
Dave
Installed a pair of the new Tour Pak hinges that Harley has and what a difference!
I could tell a big difference in the lid stability right off the bat and worth the cost just for that.
But the real shocker is in the looks. This is one of those little "final touch" items like the inner primary cover that finishes off an incomplete look that you really didn't even recognize until its done.
Went on a group ride today and every Harley rider noticed them immediately.
Best $50 I've spent with Harley in a long time.
Here you go.
Premium Tour-Pak® Hinges
Upgrade the appearance of your King or Chopped Tour-Pak® with these premium hinges. Stylized to complement the Original Equipment Tour-Pak® latches, these hinges are polished and chrome plated with no exposed hardware. Kit includes two hinges, and all necessary hardware. Drill required to remove the original equipment rivets.
79211-08
Fits '06-later FLHTC, FLHTCU, FLHTCUSE3/4 and FLHTCUTG models. Fits '06-later Touring models equipped with Color-Matched King or Road Glide® Tour-Pak® Luggage. Does not fit Chopped Tour-Pak® Luggage.
#79211-08 Tour-Pack Hinges....ordered thru my HD dealer on-line. Sharp looking. Thanks TG1 for the info.
IHP...here's one more item you must have:yes:
A few months ago a friend came over and the first thing I noticed was his new hinges. Wham.. took a trip to HD. They are just the best!!
To put these things on you have to drill out the old hinge rivets from the inside. It takes a good sharp drill bit and a steady hand. If you slip off of the small rivet you will drill through the tour pack but not to worry. The new hinge is a little wider than the old and will hide a boo boo. (experience talking) I had one slip off that put a good mark on the inside but luckily didn't go through.
You will need to pull up the lid gasket a bit at the hinge to get to the two hidden rivets. Careful as it is glued down and will try to tear but with a little patience you will be successful.
Have an extra set of hands to hold the lid steady if possible. If not then do one hinge at a time. You will also need to make the tour pack holes a little larger so the new screw will go through as they are just a little bigger than the old rivet hole.
BT, it that about the way you see it?:yes:
PS.. they are not in the picture below. That was taken a day before I installed them.. yes, have to update.
Here I am....again....reksul.
Besides the looks, are these hinges stronger and less prone to breakage and rattle than stock?
These have more beef to them and the look is second to none. The operation of the lid seems smoother as well.
As far as breakage or rattles.. hummm My lid has never rattled unless I forgot to latch it and the old hinge didn't break so I doubt this one will.
Reksul, you are right on regarding doing one at a time. I realized that AFTER I had finished. It would have saved a lot of time and been a lot easier. It also would rduce the risk of paint damage considerably since the lid would actually stay on the Tour Pak..
Also realized later that I could have done the job quicker and with less effort by just triming off the back of the stock rivets with the Dremel cutting wheel rather than drilling.
But the bottom line is that however you do it, its worth it.
reksul....about breaking. Yep, on the 2-wheelers where the TP is not mounted as solid as on a trike trunk, you get a lot of wear, stress and rattle...then they eventually break, I have replaced them on one guys bike twice now. It also depends on what you pack in there and how many times you have to open it. In my case, the wife pays no attention at all to posted weight limits. Her method of packing is to put as much as she can of whatever in the box and on top of the box. She always has to have something out of there around 20-times a day. I don't know what all she carries....I only have one spare set of underwear and some socks. Rest of it belongs to her!
The best way maybe for you to take a trip to HD to see them. The hinge is larger, the pin area looks to be more supportive and you won't have to change the air pressure after putting them on! :D:D
Can't help ya with the wifey. :blush:
LOL
Dave.. I was too excited about the install to even think of the dremel. It would be a tough job to get the ones behind the gasket though.. Did you use the dremel for all the rivets? These rivets are stainless steel and a bear to drill. They spin easily but a good split tip drill bit will cut them OK. Just have to be patient.
Since I also have a lighted wing on the tour pack I had to do one at a time or un-wire the light.. only way to do that is to take the seat off and splice it back.. no thanks.
The second I saw them I had to pay the Harley tax and get them. Best add on for the money, IMO.
No, I didn't think ofthe Dremel until afterward and I have the light wing too and I wasn't about to attack the wiring.
It was the strong rivets that made me think about it. I did drill them, but it was slow and once they started spinning it was a bear to finish off. I couldn't do it on the top, but I was able to use a center punch to drive out the bottom rivets once they were drilled down.
Just like everything else on a Harley, it's an engineer on the fly adventure.
From reading these posts, it would appear that they won't fit the 2004 Ultra classic??? Is that right.:confused:
Seems to be correct. Says 06 and later. There are others that sell a simular product but can be 3X more cost.
This was taken from another forum that was posted by an acquaintance of mine...
You can also order beautiful chrome billet hinges from Richard Pomeroy, dickelk@aol.com for $93.50 shipped USPS Priority Mail.
Eglidegoodies.com sells them for $139, OUCH:
Upgrade your fit and finish
Sold in pairs
Fits H-D tour-paks
Part Number Finish Price
plus S&H
Part Number Products Price
BH-1 Chrome Billet Tour-pak Hinges (pair) $139.99
Upgrade your H-D tour-pak's hinges fit and finish! Show chrome billet hinges replace your stock hinges with our nice chrome alternative. Provides for solid reinforcement along with beautiful chrome finish.
I hate that stupid cable also....have to make sure it's on the inside when closing the lid.
When you get the brace #, let us (including IHP) know:p
Cable sucks for sure been using a unit from E-Glide Goodies for years to replace the cable. Never had an issues with this unit even with my monster T-BAG on the lid.
Mike
OK Barb.....so when we meet one day, who will have the most upgrades???? I got vance and hines pipes. Put them on tonight.....they sound awesome. I've been looking at my hinges.....yuk....I am sure I will end up with them. But will need to buy hubby a pair too. His Ultra has been chromed to the max, but still has the old hinges. Lucky him. Someone else did all the upgrades and then had to sell, due to health. Over ten grand in upgrades.
Yikes! I'm running stock pipes:(
"I'm flying my white flag":yes:
You two ladies crack me up! :D
May she with the most shiny accessories win!!!!!
LOL...I might come close to winning the spends-the-least part (I DO wash mine!!!). I haven't added anything since I triked it in '06! Something must be wrong with me ;)
Don't answer that!!!!!
Status
snowking1979
