Tire Air Pressure
What air pressure do people with the RoadSmith HTS1800 run in their front & rear tires?
Tommy, I run 41 pounds in the BT45 up front and 28 in the rear. Wouldn't usually do that much in the rear but I carry a lot of stuff in the trunk and like a stiffer side wall. I got use to the T/A Radials on my MotorTrike and just like that feel... :xszpv::xszpv:
I use the recommended 42 psi in the Avon Cobra Trike front tire. In the rears I run 28-32 psi depending on load per Roadsmith advice. RS is a long wheelbase trike and I like the 28 psi for two-up with normal load. Also helps stabilize tire sidewall in the Arkansas twisties.
Desertgecko
