thanks to motor trike
Jul 20, 2009
59
26
Paris, TX
I just wanted to give motor trike a big thumbs up and a thank you. I had my 2008 triked at motor trike last year. The running board lens for the lights had been broken because of road rocks. I called them to find out how much it would cost to order the new lights as a replacement. Richard at motor trike said he would send them complementary to me. They actually cost $60.00 apiece. I told them that I had expected to pay for them but I GREATLY APPRECIATED it. They arrived the next day! Wow what service!!
THANKS AGAIN MOTER TRIKE for a quality product with great service.
does anybody know about the motor trike air control box , mine is constantly changing numbers while riding down the road. Is that normal? im not talking just 1or2 pounds . it will go from 30 to 60 or so while riding down the rode and not touching the thing. I don't notice any change in the ride.
Hope they steered ya'll over to the Tiger Cafe in Troop, too. Good home cookin' there.
Oops!!! Picked up the wrong thread.
It may be nothing more then the LED module freaking out. Mine went bad a year ago. Richard sent me a new one and I swapped it out. Hasn't had a single problem since. :xszpv:
It could also be the pressure "sensor" or a loose connection. There's an aluminum block next to the air compressor with 3 solenoids on it, the one in the middle is the pressure sensor. It should have a green wire attached to it with a thumb screw; if the thumb screw is loose, it'll cause that too. Seen it once or twice in my "tinkering".
thanks I ll have a look. called motor trike they said they would have a tech call me back. that was yesterday...going to call again if I cant make it work. I know how busy it can get.
if I had a prize you would win! finally got to talk to a tech at motor trike. i explained the problem and that the read out would show '435' some times . he told me that was a ground fault code and to check the ground wire and it was loose. I guess it is normal to have it read a little different while going down the road but not what I was seeing.
shawn.s.prescher
